Budget Big valve ported #6 head flow results
I finally got my heads machined and flow tested after getting the budget porting only with no sanding rolls or polishing. No fancy valve job just regular 3 angle stuff. $170 Ebay stainless 2.07/1.71 valves . Very pleased to hit my flow goals and know my Rallye 350 will run decent and have a chance. Just didn't want nor could accept the stock small valve heads as is being such a air flow bottleneck. So here ya go
.100" 65/54
.200" 135/109
.300" 201/144
.400" 225/164
.500" 237/177
.600" 242/181
.100" 65/54
.200" 135/109
.300" 201/144
.400" 225/164
.500" 237/177
.600" 242/181
I figured big valve small block heads would hit the old Edelbrock/Procomp flow numbers. I figure mine aren't far off those numbers, hope adding w 2.07" with the bowl opened up vs the current 2" with see a nice gain for the 425 SBO future build.
So far my cost in these heads are $100 at the machine shop for cutting to big valves and valve job, surfacing (guides were ok) , $200 porting at http://elliottsportworks.com/?page_id=9 , $170 for valves (Ebay-free shipping) , I did buy Crane Olds screw in studs and some guideplates also and some Ford style 1.7 cheap roller tip rockers but all that is external to the heads and transferable to anything else. I do still need to buy my springs and retainers locks which will be coming soon.
I am very much looking forward to seeing what the stock mild QB 286/286 .472 cam in my 4 speed will do with this head mod and the 3.91's. Only other mod is the ratio making it about .500" plus the zero lash manual adjustments so it can rev good. Later down the road after testing this stock 286 cam and stock appearing setup (manifolds and 2.5" mandrel bent good pipes) a swap to either an old Dual Energy Comp 275 DEH (219/233 110) or maybe a custom Howards (221/235 110 or 112) would be my preferred combo to maximize power with manifolds and maintain better low-mid torque than a W31 setup IMO
Thanks, I am excited at the potential. Especially since I decide to run headers on the Rallye to compliment flow and intake plenum mods and port matching. It should fly !
Also I did end up scoring a new in box cam cheap I can track test against the OEM 286 cam down the road. It is a Comp XE268-10 224/230 110 its about the size I was going after and $30 well there ya go
What compression is this motor? It should really fly with that bigger Comp cam, tough to beat for $30. What valve springs are you running. Looking at your flow charts, you hit the stock heads flow at .300 and gained 30 cfm intake and exhaust at .500 lift over stock heads. I know most say the 1.625" exhaust is better, curious if there would have been a gain over the 1.71 exhaust valve.
older set of new TRW (Speed pro) 6 cc forged replacement for the 68-70 310 hp engine but I don't recall if I measured deck height say 9.5-9.7 #6 heads not milled just surfaced really that I know so lets say 68 cc . I think the 1.625 versus the 1.68-1.71 is same flow with same port work just not any better is what others said. Springs are Herbert performance 1.437 110# seat @ 1.75 using about 060 worth of shims if I recall and 10 degree titanium retainers http://www.herbertcams.com/hers084tk...etainer-combo/
Yes the 1.625 exhaust is more than adequate for a small block.
And if you want to regain or retain low end tq, both of your next cam choices are wrong. You need something much closer to a single pattern. You’ve got way too much on the exhaust side.
Mark, those two big split profiles I mentioned two and half years ago when I was planning on running manifolds for stock appearance on my 3.91 geared 14" tire car for best mid range and upper rpm power with manifolds. I have since decided on running headers after scoring new Hookers cheap and to not hamper the otherwise good head flow and my current OEM 286 straight profile cam to run initially will be followed by comparing and testing the 6 degree split new XE 268 grind I got very cheap recently. As far as loosing low end maybe but it my car the rev's will be up most of the time regardless considering the drive line gearing. ALthough apples to oranges in the past my friends have had very strong running street cars with 350 SBC running the old Comp 275 DEH even when good head flow balance existed and headers too. One was a flat top 355 swapped to stock vortec 1.94 1.5 valve heads that only had a spring upgrade and valve job in a 4 speed muncie 4 door 57 chevy with 3.73 gears and he got a 12.8 in the 1/4 out of it. with say a 8.2 eighth. Same engine went into a 79 Malibu wagon budget drag car with automatic and went down to a 7.6 . Others with Trick flow heads and that cam ran similar times. Noted I am not disagreeing a loss could hurt on other cars with stock highway gears sure.
Here it is 3 years later and I just finally port matched my intake yesterday. Long block has been assembled for about two years and also the frame still off the car that long as well. I will be testing this engine in my wagon I guess after all. Don't like stuff sitting that long. Maybe the Rallye will go together next year
Don't worry. I been building my current small block for almost 6 years lol. Its got run time on the stand but I found some rocker arm clearance issues ( hitting the poly locks). Fixing that then should be good. Car has been down all year ( sold the last engine ) trying to maybe get it out in the fall for some shake down runs. Its a budget build but lots of horse trading and bartering and trading labor was involved lol. I think 11.70's is realistic.
I look forward very much seeing your car keep hitting the new goals. Great job ! I am about to pull the "mule" 350 out of the wagon this weekend. Its assumed "the position" yesterday. The "Good" 350 for the Rallye 4 spd in the wagon will get the headers and a 2500 12" stall. Thinking it may do some solid 13's with the 3.08's in the wag. I did meet my goal of busting into the 11's in my 63 Catalina this year on a 255/60 drag radial with the same engine that was in the wagon two years ago. That was in hot weather too so my Fall it should see mid 11's with no real changes. I did swap to a oldWarrior intake though to help shift my torque peak higher and better match the converter. For the record though I have ran 7.5 in the 1/8 with both the cast iron one and the Warrior though.
