350 intake on a 330?
Old October 20th, 2014, 09:53 PM
cjsdad's Avatar
Everything I have read makes me think it should work, but the intake I have is from a '73 350. It was a freebie and was pretty gunked up when I got it.
But it cleaned up pretty well. First with a spray off with the pressure washer, and then a couple days in a rust remover bath.
1. My engine needs new head gaskets so I will be taking the two-barrel intake and carb off anyway so will there be any problems with putting the 4-barrel on? I still need to get a Q-Jet for it.
2. This intake is made for an EGR valve. Can I simply block that off?
3. Should I block off the holes under the primary openings? It looks like I can drill the holes out and tap them for plugs, would that be worth the effort?
Any advice or heckling is welcome.
cjsdad is offline
Old October 20th, 2014, 10:14 PM
1. No
2. Yes
3. I left them as-is on my Performer 350 intake and I don't think it hurt anything.
Fun71 is offline
Old October 20th, 2014, 10:48 PM
64Rocket's Avatar
If it was me I would tap the egr holes and plug them up, just for peace of mind for me.
Gene
64Rocket is offline
Old October 21st, 2014, 07:48 AM
edzolz's Avatar
I would look around for an A4 aluminum intake from a later Olds. They are lighter and a better performer than the one you have. If you do find one, un-screw the EGR tubes and plug the holes.
edzolz is offline
Old October 21st, 2014, 05:45 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Plug the holes under the primaries and run it.
Be sure to check the underside of the manifold for cracks. mine was split about 2 inches.
J-(Chicago) is offline
Old October 21st, 2014, 08:32 PM
Redog's Avatar
Should work fine. 64-84 SBO were all the same
Redog is offline
gwgarage
November 10th, 2018 04:51 PM
fast67vellen2o
October 24th, 2010 06:11 PM
scubastever
August 27th, 2010 12:20 PM
jjcus
November 9th, 2009 09:30 PM
Quick Reply: 350 intake on a 330?
