330 cam options
Old August 19th, 2014, 11:31 AM
iceberg8389's Avatar
330 cam options
new member here.....would like to upgrade the cam/lifters/springs in my 330. it has factory valve train as of right now. i have an edelbrock performer intake as well as an edelbrock performer carb. i do understand that it is a 45 degree bank angle.
i am wondering if anyone has any suggestions as to what direction i should go? right now i am considering the crane cams #790531 with a set of their hydraulic lifters and springs.
http://www.summitracing.com/parts/crn-790531
not looking for anything too aggressive, just something to get it breathing a bit better and get some more power in the 1500-5500 rpm range to match the edelbrock intake power range.
i have also sent a message to cutlassefi as i have seen his name brought up in other threads about custom ground cams, hoping he gets back to me.
iceberg8389 is offline
Old August 19th, 2014, 11:53 AM
Oldsmaniac's Avatar
There is some bad info out there on cam angle of the 330. The 1967 330 is a 39 degree block.
Oldsmaniac is offline
Old August 19th, 2014, 12:12 PM
this is a 65 330, which i am pretty sure is a 45 degree
according to this ordering guide from crane cams, the 67 330 is also a 45 degree:
http://www.cranecams.com/pdf-tech-ti...ont270-271.pdf
HOWEVER, in this chart i found on 442.com it says all 64-67 330's are 39 degree....very confused now:
YEAR CID MODEL LIFTER DIA. CAM BANK ANGLE
1964-67 330 ALL .842 39deg
1965 400 ALL .842 45deg
1965 425 ALL .842 45deg
1966-67 400 ALL .921 39deg
1966 425 exc.Toronado .842 45deg
1966-67 425 Toronado .921 39deg
1967 425 exc.Toronado .842 39deg
1968-69 400 ALL .842 39deg
1968-80 350 ALL (gas) .842 39deg
1968-76 455 ALL .842 39deg
1975-82 260 ALL (gas/dsl) .842 39deg
1977-79 403 ALL .842 39deg
1978-80 350 ALL (diesel) .842 39deg
1980-84 307 ALL .842 39deg
1981-85 350 ALL (diesel) .921 39deg
1985-86 307 ALL .921 39deg
Old August 19th, 2014, 03:26 PM
Justin
oldstata's Avatar
From my understanding the 45* cam needs to be custom ground there is a lot of threads where members have installed off the shelf ones and it was. The 39* cam I would contact
( cutlasefi ) he is a member here and can custom grind you one per your build and it's not much more or cheaper then off the shelf cams
oldstata is offline
Old August 19th, 2014, 04:38 PM
Spoke to a gentleman at rocket racing....they offer a full package for the 330. Cam, lifters, valve springs, timing gears & chain (roller), adjustable rocker kit, etc. Its everything I need to upgrade the cam/valvetrain the right way. Price tag comes in at $1000 for everything. And he confirmed my engine is a 45 degree. They custom grind the cam based on everything else done to my car, I feel I am in good hands with their help. He asked what bolt ons I had, stall, exhaust, tranny, intake, carb, gears and should get back to me tomorrow with the cam profile he would suggest. I will follow up on this thread when I know more.
Old August 19th, 2014, 04:41 PM
Justin
oldstata's Avatar
That's good and yes 65 330 is a 45* I think cutlassefi could do better on the price but maybe I am wrong I would at least check if you haven't bought already
oldstata is offline
Old August 19th, 2014, 05:01 PM
cutlassefi's Avatar
Yes I can thank you oldstata.
Cam, lifters, Cloyes Billet Double row chain set, Full roller adjustable rockers, studs, guide plates, springs, retainers, locks, $800.00 to your door, any grind.
Just left you a pm iceberg.
Thanks!!
cutlassefi is offline
Old August 19th, 2014, 05:38 PM
L69
L69's Avatar
Iceberg that is a deal from cutlassefi!
L69 is offline
Old August 19th, 2014, 06:14 PM
Sounds good to me! I just emailed you cutlassefi....just would like a little more details on what I'd be getting from you.
Old August 21st, 2014, 08:58 AM
88jetstar's Avatar
not to thread jack, but does that mean this cam also wont work with the 64-66 330s?
http://www.jegs.com/i/Edelbrock/350/7112/10002/-1
thanks
88jetstar is offline
Old August 21st, 2014, 09:01 AM
Justin
oldstata's Avatar
thanks
I would say no it's a 39* bank angles 64/65 330 not sure on 66 is a 45*
oldstata is offline
thanks
that looks to be the 39 degree....i was looking into the edelbrock cams as well but can't seem to find anything for 45. not to say they don't offer them, might need a call into edelbrock directly to find out.
Old August 21st, 2014, 09:32 AM
88jetstar's Avatar
I was just curious sounds like cutlassefi would be the way to go
Old August 21st, 2014, 04:16 PM
cutlassefi's Avatar
It's simply a program change, the cam cores are the same for a 39 or 45 flat tappet. However most cam companies don't want to fool with it because of the low demand.
Oldsmaniac
June 20th, 2014 05:44 AM
Koda
May 9th, 2014 07:07 PM
Boilerz25
March 5th, 2014 06:01 PM
cutlassrichard
May 1st, 2013 05:40 AM
July 5th, 2012 09:34 AM
Quick Reply: 330 cam options
