Hydraulic valve lifters
HI guys
I've got a new noise on my engine. It's a 307 and if the engine is cold there is a nailing noise, but after ca. 3 km of driving the noise isn't anymore. Could that be the hydraulic valve lifters? It's only when the engine is cold.
Thanks! 98regency
Thanks! 98regency
Changing to a thinner oil is certainly easy enough. Why not?
Might be dirty lifters- might as well try a motor flush chemical just before the fresh oil. Might be dirt particles that a flush will not remove, though.
Check the rockers for wear perhaps? A good excuse to replace valve cover gaskets.
You can use a piece of hose as a stethoscope to pinpoint noises- hole one end to your good ear and put the other end here and there to find out the source of a noise.
If it goes away within a few minutes, is it really worth a lot of attention though?
"If it ain't broke, don't fix it" as they say.
Ok, I'll try to check this.
Your right, but I think I better do something now and so I can prevent damage in the future ^^ I think when there is a nailing noise there's something running without or not enough oil :S
Part of the problem is translation- "nailing" noise could be anything from a ticking lifter- light tick tick tick sound, to detonation- harsh rattling sound, more random than the regular ticking of a loose lifter- to the bang bang bang of a rod bearing spun and eating its way thru the crank.
Can you have a local mechanic take a peek at it?
There is no garage in my area which has experience with us-cars. I do all by myself. I have enough experience to say, it's not a bearing.. It's something with the lifters..
Could be that the oil in the lifters drain off when the engine is not running for a couple of hours and then when the engine is cold and I start it the thicker oil needs too long to fill the hydraulic valve lifters . This can be the reason for the nailing noise in the first few minutes.. It's more a tack tack tack tack...
So I'm going to try a thinner oil at the weekend.. Maybe it helps :P
507OLDS
November 12th, 2012 06:36 AM
