What kind of performance to expect?
I just had my 350 Rocket rebuild for my 1972 Cutlass Supreme and I'm wondering what kind of performance should I expect?
The car has:
Edelbrock Performer Intake
Lunati Voodoo 262 Cam
Holley Street Avenger 770
#7a heads
Compression I believe was 9:1
Bored over .030
Hooker Long Headers
2.5 inch exhaust all the way through
Spintech Super 9000 Mufflers
Eaton Posi
The car has:
#7a heads
Bored over .030
Hooker Long Headers
Eaton Posi
I thought the carb was a little big as well as I originally had a 650 edelbrock but the guy at the shop that rebuilt my motor insisted that I needed atleast a 750 because of something with the way the intake is made?? Beats me...I started the car for the first time this morning and I'm excited! Can't drive it yet until I put some brakes on that bad boy but I'm ready to see what I have!
fwiw I ran 13.89's with a mild 350 in my 72 when it was still in all steel form and a gutted interior. It was a 73 350 freshened up and 72 heads with a comp 260h cam edelbrock performer intake 600 cfm carb hei full length headers 9 to 1 compression running only the water pump and alternator. I went to a 3.73 gear and saw no real gain in performance then I added an x pipe and went 13.8's all day. I did a lot of tinkering to get my mild build to run what it did. But it was very very mild.
Sounds like I'll be satisfied...I don't plan on doing a lot of flying in the car but when I want it to get up and go I don't want to be disappointed! Those times you all are mentioning are 1/4 mile times I take it?
Yes. If they were 1/8 mile times you would be sorely dissapointed I assure you!
What cam are you refering to when you say 'Voodoo 262'? Are you refering to the one with 213/219 duration @ .050 lift ( 256/262 advertised )? If so, and you really have 9:1 CR, you have a good tune, and you get decent traction with some drag radials, you could dip into the 13's.
Dead Reckon
December 29th, 2013 02:24 PM
Finn5033
October 10th, 2012 03:10 AM
IB ATEST
January 27th, 2009 12:32 PM
