belt squeal after replacement
Old March 16th, 2013, 04:44 PM
JuzCallMeDee's Avatar
just changed fan clutch, all three belts and replaced alternator. now i have a very loud squeal. belts are tight with the 1/2" play. the belt doesnt really fit in the alternator groove flush. it doesnt jump off or anything but its not flush. i was told to just get some "belt dressing". need you guys help
Dee
JuzCallMeDee is offline
Old March 16th, 2013, 04:51 PM
M-14's Avatar
The dressing stuff is a waste, you need to find the right belt for the alternator, it should be wide enough to sit on the pulley just about flush.
M-14 is offline
Old March 16th, 2013, 05:11 PM
If the belt doesn't fit, then you have a problem - either the wrong sized belt, or the wrong sized alternator pulley.
Fix that problem and you're set.
You say you have ½" of play - how hard do you have to press to get that ½" of deflection?
MDchanic is offline
Old March 16th, 2013, 08:11 PM
here's a couple pics...
looking at the old alternator, the pulley sizes are different.
Old March 16th, 2013, 08:37 PM
i dont have to press hard...
here's the alternator i have
http://www.summitracing.com/parts/tff-7102ncp
Old March 16th, 2013, 09:01 PM
hookem horns's Avatar
Alt belt in top pick does not look real tight but hard to tell in a picture. Search for Joe P's many write-ups on how to properly tension the power steering belt, it's a common culprit.
hookem horns is offline
Old March 16th, 2013, 09:10 PM
Looks like the wrong alt belt. It's likely slipping instead of gripping the pulley. Try this: remove the Alt belt and leave the other 2 on properly tensioned. Start the car and see if the squeal is gone. If it is, the alt belt is the problem.
The PS belt looks fine. The alt belt should fit the same way.
Allan R is offline
Old March 16th, 2013, 09:26 PM
The belts look loose just at a glance.
I've never seen a motor run with belts that loose.
Different in diameter or in width?
You want about a half inch deflection pushing hard. Not as hard as you possibly can, but very firmly.
MDchanic is offline
Old March 17th, 2013, 05:51 AM
the width of the groove
Old March 17th, 2013, 05:53 AM
im gonna tighten the ac/fan and ps belt a little and remove the alt to see if that gets rid of the squeal. ill let you guys know how that goes.
Old March 17th, 2013, 07:59 AM
And you ARE aware of the proper way to tighten the PS pump belt, using all three fasteners, right?
joe_padavano is offline
Old March 17th, 2013, 08:22 AM
Ahh, Joe, such faith...
MDchanic is offline
Old March 17th, 2013, 10:27 AM
Yeah, it's not like every single squealing belt thread comes back to the PS pump belt or anything...
Old March 17th, 2013, 12:45 PM
yes, from one of your post i think. metal tab behind the pulley.
Old March 17th, 2013, 12:52 PM
got a better fitting belt for my aftermarket alternator and the squeal is gone. thanks allan r and everybody else
anybody need an alternator belt (black one in pic). it fits my original alt perfectly. came from napa.
Old March 17th, 2013, 01:50 PM
Is that a green belt?
If so, then, as far as I know, it's for yard equipment - designed to put up with duty as a clutch mechanism, with an idler wheel tensioning it, but not designed for the potentially higher-RPM use on an automotive engine.
Someone here who's "in the business" may be able to shed more light on it than I, but that's been my understanding.
MDchanic is offline
Old March 17th, 2013, 02:07 PM
it is green and looked funny to me. do they make alt belts that are a lil more narrow?
Old March 17th, 2013, 02:24 PM
Belts are made in standard sizes, and belts for our cars should all be 15/32" wide at the outside, with a 36° wedge shape. They do make belts that are ½" (16/32"), which would stand out from the pulley, but you should have not gotten one of those, as they are not, as far as I know, used for cars.
If you poost the numbers of the belts in question, one of us should be able to tell you whether they were the right ones.
MDchanic is offline
Old March 17th, 2013, 02:47 PM
m371961's Avatar
If the width of the groove in the aftermarket alternator pulley is different, there's the trouble. Let me guess, it is more narrow.
m371961 is offline
Old March 17th, 2013, 02:51 PM
ctsplicer's Avatar
Been thru this many time.Swap the pulley from your old alternator and the problem will be solved.
ctsplicer is offline
Old March 17th, 2013, 03:21 PM
brown7373's Avatar
If you used a narrower belt to fit the pulley of an aftermarket alternator, then it is going to be too narrow for the other stock pulleys, and you may tear up the belt, or it might start squealing from the other pulley. Like ctslicer said, change the pulley.
brown7373 is offline
Old March 17th, 2013, 04:08 PM
these numbers?
Old March 17th, 2013, 04:09 PM
what tool do i need to replace the pulley. that nut on the pulley doesnt come off does it?
Old March 17th, 2013, 05:29 PM
Belt #15550 (Dayco, among others): 15/32" wide, 55.0 inches.
Belt #4912 (FrigiKing refrigeration products): same as NAPA, CarQuest, & Gates 7380, 10mm wide (7/16"), 38.5" long.
I'm not sure, but the I believe that the 4912 is narrower than the 15550 (aside from their different lengths), and that it's too narrow for this car.
Any belt experts out there who can confirm or deny?
Oh, it'll come off - use an air wrench and put an old belt around the pulley and into a vise, tight.
By the way, what are the year and engine of your car?
MDchanic is offline
Old March 17th, 2013, 07:07 PM
70vert's Avatar
those green equipment belts are not designed to be used in an automotive application. Last year we used one on the late model in a pinch and never replaced it untill i realized that it had eaten the aluminum lower pulley and then belt then slipped no matter how tight you got it
70vert is offline
Old March 17th, 2013, 07:20 PM
Octania's Avatar
A handy tool, if you have the correct tension number to shoot for:
http://www.ebay.com/itm/BURROUGHS-BE...05ae7e&vxp=mtr
Octania is offline
Old March 17th, 2013, 09:28 PM
Eric, it's a 72 CS vert. Pics in his album
Allan R is offline
Old March 18th, 2013, 07:10 AM
Yes, with a 350
Old March 18th, 2013, 07:12 AM
Auto parts store can remove the pulley can't they?
Old March 18th, 2013, 12:02 PM
They probably can, but may charge you? IDK. What Eric said works. If you don't have air tools (which I've found make the job sooo much easier) clamp the pulley as he said and use your socket wrench with a snipe (2 or 3' hollow pipe) to get the leverage you need.
I haven't had to replace my alt pulley, but if it's like the PS the pulley will have a keeper and keyway you'll see once that nut is off. From there it should just be a wiggle or light pry with a screwdriver to get it started and off. You'll have to do this 2X - one for your OEM and one for your replacement.
Allan R is offline
Old March 24th, 2013, 06:55 PM
  #31
napa replaced the alt pulley the other day so the belt squeal is gone. thanks for all the help. now i have a couple other problems.
1. there's a squeaking noise (not very loud).
2. new battery (along with new(100 amp) alt) is dying. there is a spark when i connect the jumper cable. not driving the car at all. ran the car for about 30 mins while flushing the radiator. what could cause my new battery to die if i havent turned on anything electical?
Old March 25th, 2013, 07:27 AM
  #32
Kinda hard to help here without more info. Could be a shock, could be suspension bushings going bad, could be a dying mouse...
Is this new alternator a "one wire" alternator? It's apparently aftermarket since there are no factory "100 amp" 12-SI alternators that I'm aware of. Also, if you started and ran the car, you turned on something electrical.
Old March 25th, 2013, 08:10 AM
  #33
1. squeaking when idle (im not driving it right now)
no mice i hope lol
2. its a three wire alternator
Old March 25th, 2013, 10:16 AM
  #34
brown7373's Avatar
A few years back, I bought an alternator from Discount Auto Parts for a 1970 Pontiac. It squeaked almost all the time. A NAPA alternator corrected the problem. After that, I stopped buying cheap auto parts. I'd buy a new Delco or one from NAPA, but beware off brand, no brand or house brands of discount chains.
Old March 26th, 2013, 08:35 AM
  #35
alt didnt squeak when i had the green belt on it...
Old March 26th, 2013, 09:35 AM
  #36
Couple of comments/questions
1. NAPA could have damaged the alt bearings if they were sloppy pulling and replacing the alt pulley. Take it back and see what they can do. It's possible the alt may have been making this 'squeak' earlier but you didn't notice it with the noisy belt. They should be able to replace the alt under warranty - don't forget to change the pulley!
2. Why was the alt replaced in the first place? Was the battery going dead then too; as if it wasn't being charged enough?
3. If the battery is going dead while the car is just sitting, you have a power drain somewhere. Could be as simple as a glovebox light that doesn't go off. Test for parasitic draw on the battery. Here's a how to video that might help you do the test. Easier to just watch and grasp principles than type this all out. Testing for draw has been discussed before on the site. I know your car isn't computer controlled, but the principles are the same. You'll have to keep the door switch pressed in while you pull fuses in the car till you find the power draw. (luckily you only have one fuse box) If you've changed out or installed an aftermarket stereo/amp in the last while? My money is on that being the problem.
Allan R is offline
Old March 26th, 2013, 02:25 PM
  #37
i did read the other posts, and this vid makes it alot more clear. i will check asap and get back to you guys.
with the green belt (which wasnt for cars/heavy duty) everything was quiet so it may be the fact that NAPA changed the pulley for me and ill keep that in mind
Johnny Cage
February 28th, 2013 02:28 AM
deltaboy
February 6th, 2013 01:01 PM
kplange
January 7th, 2012 07:11 PM
hunter
November 18th, 2011 11:45 AM
JBrooks
May 27th, 2010 02:59 AM
Quick Reply: belt squeal after replacement
