71 cutlass 350 stock th350 tranny stock
Hey guys just wondering if anybody knows why when Im on the hiway say going 65 or 70 and I let off the gas my cutlass seems to make a popping or kind of backfire noises....I know its not back fire the RPM's are over 3000, When I put my headers on and had open headers going to mufller shop I could hear it worse then i got pipes welded to collectors and know still hear it but not as bad as with open headers.Any suggestions thanks
Sorry, on my edelbrock 1406 carb, there are two idle mixture screws. I turned them both in about 1/2 a turn. The popping stopped almost completely. At 80mph at WOT if I let off completely, it would pop a couple of times and stop. I assume thats normal.
But again, leaning the car out like that did negate performance around 30-35mph. Second gear didn't seem to have the same pull, so I turned them back out.
I may have a slew of other problems, but this happened to me. Maybe someone else can explain as to why.
Leaning the idle air/fuel mixture will have no effect on your performance off idle. So you have another problem.
As copper said, it's normal, unles it's a very loud backfire. Hi flow exhaust are a bit noisier than stock.
But granted the other problem is not related and relates to another cause.
gscott819
July 28th, 2009 07:02 PM
