330 teardown - help me solve what these mystery parts are
I just pulled out my 330 for a teardown and in the process found 3 bearings on my shop floor. I am actually thinking these are valves for my oil and transmission cooler lines. I've attached a pic for reference.
I have not torn the engine apart, just pulled it out and they must have just dropped out when I took the engine apart but the lines are the only thing I can come up.
Any ideas what these may be for?
Never seen them in any part of an Olds motor before. You sure they came from the motor?
Checked the hoist. The cheap thing doesn't even have bearings in the castors. Like I said, small chance they are not from the motor/tranny somewhere.
Anyone know if cooling lines in a 65 cutlass with jetaway transmission had a check valve?
Yes, sure they are not. You are right, the swivel castors have bearings but none are missing and these bearings are about 2x the size of the castor bearings.
No damage to the steering box. I had already checked that.
....the mystery continues.
Maybe they don't belong to the motor, tranny, or anything else attached to the car. I just better make damn sure it's not when I put the thing back together.
garneyflanch
June 28th, 2012 09:31 AM
