power steering pulley alignment
Old May 14th, 2012, 10:41 PM
Fakser's Avatar
Ok I have used the search function and read some good posts about brackets and spacing of the power steering pump. I am experiencing a misalignment of my power steering pulley. It's a 2 groove pulley I have all of the correct spacers in place but the pulley seems to be sitting too far back by about half of a groove. Is there a spacer that goes behind the pulley that I may have misplaced? I can't adjust the brackets because the bolts line up and dont have enough tolerance to move that far either. Is their a difference between pumps or pulleys between AC and non AC? This is my first olds build and these brackets are kicking my butt. Any help, tips or comments will be greatly appreciated
Fakser is offline
Old May 15th, 2012, 03:10 AM
If you have TWO round spacers, like thick washers, on two of the mounting bolts (exhaust manifold and "extra front motor mount" hole), then you've got them all.
This question implies that you have mixed pulleys.
That's illegal in the South .
But seriously:
There are a variety of different pulley configurations, depending mostly on year and options (A/C, P/S, HD cooling, etc.). You MUST use ALL of the pulleys from ONE engine together in oder for them to work together (yes, there are ways to mix them, but getting that to work is basically just luck).
If you've got pulleys on there that came from different cars or engines, you'll need to swap around until all of the pulleys came from one place.
MDchanic is offline
Old May 15th, 2012, 07:58 AM
Randy C.
rcorrigan5's Avatar
Let us know what you have (picture looks like a '68 or '69 Cutlass?) plus what its options are (power steering, A/C, heavy duty cooling) and someone here should be able to tell you the pulleys needed for your configuration.
Randy C.
rcorrigan5 is offline
Old May 15th, 2012, 03:37 PM
"Exhaust manifold"??????
Uh, you mean the lower front cover stud, don't you Eric?
joe_padavano is offline
Old May 15th, 2012, 04:14 PM
Curses! Wretched memory.
MDchanic is offline
djhoth
January 24th, 2012 09:33 AM
msco123
March 9th, 2010 10:13 AM
oldsonharmont
Suspension & Handling
February 9th, 2010 06:35 PM
68Tom
September 16th, 2009 11:34 AM
mcutlass1969
March 26th, 2007 07:09 AM
Quick Reply: power steering pulley alignment
