mysterious rubber flap in front of radiator ?
Old May 5th, 2011, 08:26 PM
knighthawk's Avatar
Location: from Wisc, then Texas, then Kansas, now back to Texas,
in front of the radiator, inside the grill, on the left side (drivers side) is a thin rubber flap about 8 or 10 in. square...... where does it go ? one corner of it is still fastened to the upright
''shroud'' near the rad support it has about a 1'' hole in it with a 'slit' to the edge. The one for the other side is missing..I assum I need these for air flow control. ???????????????
knighthawk is offline
Old May 6th, 2011, 07:24 AM
Lady72nRob71's Avatar
Could be....
What year and model?
Lady72nRob71 is offline
Old May 6th, 2011, 11:06 AM
knighthawk's Avatar
I'm sorry...'69 S, (white convertable)
Old May 6th, 2011, 12:16 PM
Shizzy's Avatar
I don't own a 69, but it probably there (factory) to help direct the air through the radiator instead of around it.
Shizzy is offline
Old May 6th, 2011, 01:15 PM
Yep - thats what it is for an what it does.
I think there is supposed to be one on each side of the radiator...
Old May 6th, 2011, 01:18 PM
delete
droptopron's Avatar
They sell them repro but I don't recall what they are called. They are meant to direct airflow thru the radiator & not around it. On a '70 the bottom goes to the radiator support & the top goes to the radiator top plate. IIRC '70 had two different sizes for standard or heavy duty cooling.
droptopron is offline
Old May 6th, 2011, 01:42 PM
knighthawk's Avatar
I have to wait a few days now for a new radiatror, so now wouldd be a good time to put them in............Year one or OPG shuold have them , I would think, if now I only knew what they are called ..........
Old May 6th, 2011, 01:57 PM
Cutlass Lover
cutlassgal's Avatar
Fusicks has them too. According to Jamesbo, they're called "radiator flappy thing-a-ma-jigs", lol!!!
cutlassgal is offline
Old May 7th, 2011, 03:08 AM
Yellowstatue's Avatar
There is also a flap that fits around the park light on a '69 to keep crud off the light housing that is projected forward from the rotating wheel assembly... The one inch hole with slit goes around the bumper brace and surrounds the light housing...play with it, you will figure it out.
Last edited by Yellowstatue; May 7th, 2011 at 03:11 AM. Reason: Intelligence update!
Yellowstatue is offline
Old May 7th, 2011, 06:56 AM
442much's Avatar
Sorry Sandy I think you mean "radiator flappy rubber thing-a-ma-jigs", not to be confused with "radiator flappy thing-a-ma-jigs".
442much is offline
wgonzo64
October 15th, 2014 04:03 PM
Propaneking
July 3rd, 2012 06:42 PM
willj
May 12th, 2011 09:01 AM
Big John 85
April 6th, 2010 06:40 PM
BigBertha442
February 18th, 2008 08:03 PM
Quick Reply: mysterious rubber flap in front of radiator ?
