PCV hitting rocker
Old March 25th, 2019, 08:03 AM
Matt Joseph's Avatar
PCV hitting rocker
Hello everyone,
Just finished the overhaul on my 350. I have a set of aftermarket valve covers on it, just basic chrome jobs. I知 noticing my PCV when installed is hitting the top of the rocker. Has anyone else experienced this?
Matt Joseph is offline
Old March 25th, 2019, 08:27 AM
There should be a baffle in the valve cover to prevent oil from being sucked into the pcv. Can you post a picture of your VC's, pcv, and breather.
oldcutlass is online now
Old March 25th, 2019, 12:27 PM
Here here is a pic. My breather is just a push in. You can see PCV on the other side. I believe the issue is the PCV itself. I think with these covers I need the 90 degree valve with a flat bottom where what I have is a valve that has an extra nipple on the bottom. Here is what I知 thinking is the issue...
Old March 25th, 2019, 02:10 PM
Apparently your video is just a picture. If I understand you correctly, you have the bottom pictured pcv (which is an inline type) stuffed into the grommet with no baffle and the end is hitting a rocker arm? If that is the case, yes go get a 90* like middle pic and use the other valve cover that should have a baffle and move the breather to where the pcv is now.
Old March 25th, 2019, 02:49 PM
Your problem is that you have aftermarket valve covers with some random location of the PCV hole. The factory valve covers located the PCV BETWEEN the rockers so there would be no chance of contact. Do you have stock rockers or aftermarket?
joe_padavano is offline
Old March 25th, 2019, 05:07 PM
Yeah the picture if motor is a screenshot on my phone. I figured the issue was with valve covers not having the hole centered. I知 going to pick up a set eventually and put the factory PCV and breather setup on. I値l get the 90* until then. Thanks for the help guys. Just for record they池e stock rocker/bridge assembly. The valve covers are the ones already on engine when i bought so I used them
Old March 25th, 2019, 06:05 PM
OEM Olds 350 Valve Cover
Vintage Chief is online now
Old March 26th, 2019, 06:36 AM
I'd try the right pcv first, the one your using was never intended to be used in the VC. I'd put it where the breather is if there a baffle there. If not then get another set of VC's
Old March 26th, 2019, 09:21 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
^^^What Eric said^^^ PCVs are specific to the application not only in the shape and size but also in the internal spring/seat/valve pressure. Get it wrong and it wont idle right or the PCV wont remove the blow by.
Steve
droldsmorland is offline
Old March 26th, 2019, 01:16 PM
Thanks for the help guys. I知 going to pop the new PCV in when it arrives and see how it goes. A new factory set of covers is in the near future
Old March 26th, 2019, 03:47 PM
Toro X6's Avatar
And in addition to the details already stated, get the correctly shapped Oldsmobile PCV Grommet for your rocker cover too.
https://www.inlinetube.com/products/INL10900
Other sources are likely available...
Toro X6 is offline
WannaBa442
May 22nd, 2019 06:27 AM
Almond900
February 26th, 2016 02:56 AM
tgilligan
March 22nd, 2013 01:35 PM
67Olds442X2
May 22nd, 2011 05:28 PM
mgue67
April 28th, 2010 10:27 PM
Quick Reply: PCV hitting rocker
