Motor Mount Heat Shields & Headers?
I've owned four Oldsmobile A-bodies over the years, and none of them had the heat shields on the motor mounts. None of these cars had headers, all of them had the factory cast iron manifolds. I'm getting ready to install headers and the full exhaust system on my project which leads me to these questions:
1. Do the head shields really help extend the lifespan of the motor mounts?
2. Will the heat shields even fit with headers?
Here's a link to the heat shields: https://www.opgi-static.com/common/C...v=103020131004
Oh, and it's a small block with Hooker 3901 headers. Thanks!
Over the years I've come across dozens of these. I'm thinking if they didn't work the factory wouldn't have gone to the trouble and expense. Not sure about fitment with headers, but if it were me I'd try installing it on the engine stand and see if the headers fit OK.
I would just find a pair like 2blu442 offered up IMO.
Eric
John:
How much would you want for a pair of these heat shields and do you think you could find a good set? In Line Tube sells them for $19 each but not sure about the thickness/quality of the stamping. I've had enough problems with repop'd parts to make me want some salvaged stock parts. I would want a solid pair; i.e. not rusted out, thin metal, pin holes, etc. Thanks!
Rodney
Rodney
