Intake Manifold
Intake Manifold
Members, just picked up an intake manifold for my '69 350 at a local swap meet. After checking the casting # (390327) it looks like it was made for a '66 330 (4V).
wanted to know if it will fit my engine & that the runner design/flow would be the same as a period correct manifold (4V). Not worried about choke set up as I have a Qjet w/
electric choke going on it.
Thank !
Thank !
Thank !
Thank !
Joe, the intake that's on car now is an Eddy 3711 & the dizzy has been swapped for an
hei unit. Would those things have any bearing on needing the (2) sensors @ manifold ?
Just wanted to go back to a somewhat period correct cast intake.
Thanks !
Thanks !
I question your desire to change the manifold, however. The HEI isn't "period correct" either. And frankly, if your goal is to just hide the late model E-brock intake, I'd simply grind off the logo, sandblast to eliminate the grinder marks, and paint the aluminum intake engine color.
