Mini starter making screeching sound in gear
My stock starter went out and having headers it was so tight getting a new one back in.. so I bought a powermaster mini starter. Now when I put it into drive and rev the engine it makes a screeching sound. It sounds like maybe the starter is rubbing against the flex plate. I checked the bolts and the flexplate is tight
The starter isnt in a bind against anything pushing it at a weird angle. I've tried it in three or four different positions.. I've tried it with shims and without.. same issue every time. Anyone have any ideas?
edit: Car is a 71 Cutlass S.. with 350 motor.
Have you installed the shim that goes between the starter motor and the mounting base?
This is for illustration purposes, you need the one for your starter.
https://www.summitracing.com/parts/pwm-624
Yep, you need a spacer to gain the right distance. I had the same problem with the powermaster. The starter teeth need to move back, to get clearance away from the flywheel ring. It's different from a normal starter shim that moves them down.
Btw, in an emergency pinch, if you have some thick solder about the same thickness as their spacer or a tad more, you can cut the right length of solder off, to space it out and go around and that worked for me, on my 455. These go between the aluminum adapter block and the starter itself, then bolt them back together, and then bolt back onto the engines. Hot Rod ingenuity.
Mine was bought a few years ago from them and didn't have a spacer back then either. In fact what they sold was not a spacer washer but a spacer plate, if I remember right, and cost extra if you needed one.
