Can I mix "steel" exhaust valves with SS
Old May 24th, 2018, 07:00 AM
Mrgadget's Avatar
I had a timing gear issue which caused my 350 to bend 3 SS exhaust valves.
The ones I find on Summit (Sealed Power V-1770) are the correct dimensions, 1.562 dis,.343 stem and 4.728 lgth, but they are "steel".
Can I use these safely with my SS ones?
Thanks, Frank
Just found out these are stainless........tech guy from Summit looked info up on Fed Moguls website, so I'm good with these.
Mrgadget is offline
Old June 1st, 2018, 12:28 PM
BillK's Avatar
I know this is a few days old but ....... I do not think those are stainless valves. They are listed in the Sealed Power stock replacement catalog. I would call Federal Mogul just to be sure. 800-325-8886
BillK is offline
Old June 2nd, 2018, 08:47 AM
Mrgadget's Avatar
Thanks Bill, I went to Fed Moguls site (www.fme-cat.com) and looked up my part, V-1770, it is made of 21-2n which is a stainless material.
Frank
Mrgadget is offline
kansjfr
July 14th, 2014 09:13 PM
Olds Scott
April 3rd, 2014 04:50 PM
Nasty455
January 9th, 2013 05:56 PM
nonhog
July 4th, 2011 02:39 PM
aaronlife
August 30th, 2010 09:51 AM
Quick Reply: Can I mix "steel" exhaust valves with SS
