Chart/specs for flow on SBO heads
Old May 16th, 2018, 08:58 PM
Via3d's Avatar
Are there any spec/charts for the flow or port sizes on the various SBO heads?
I have seen some experienced Olds enthusiasts suggest both the #4 and 5's ... probably the 5's suggested most as best flowing. I haven't seen any data are specs regarding....
Via3d is offline
Old May 17th, 2018, 07:14 AM
First, all of these "head flow" charts are typically based only on measurements of one or two heads. The manufacturing tolerances are greater than the differences you find in these tables. Bottom line is that any SBO head prior to the no. 8 smog heads will flow about the same as any other, given the same valve sizes. People loose WAAAAY too much sleep agonizing over this.
joe_padavano is online now
Old May 20th, 2018, 05:41 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Yes and #8's with a bowl hog on the exhaust bowl match early heads for flow. The later number then large "A" heads, all suck and need port work to flow as much as earlier heads.
olds 307 and 403 is online now
Toocool
February 15th, 2018 12:34 PM
QS442
April 12th, 2016 07:58 AM
QS442
August 12th, 2014 05:56 PM
Octania
February 9th, 2013 11:53 PM
shaks 442 clone
October 18th, 2008 09:41 AM
Quick Reply: Chart/specs for flow on SBO heads
