short waterpump non AC 71- cutlass 350
...found it : AIRTEX AW773 --
1967 OLDSMOBILE CUTLASS SUPREME 5.4L 330cid V8- 5,1" long
As with motor mounts, nearly every vendor gets Olds water pump listings wrong. The factory part number is 231065. Unfortunately, that pump is no longer available new anywhere. Supercars Unlimited says they have rebuilt units. Alternately, you can use Airtex AW773, available from RockAuto. This is for a mid-60 application but it will work on your 71. The only issue is that the inlet diameter might be different from the one you currently have. You might need to swap the lower radiator hose to match. 68-70 Cutlii used a 1.75" inlet, 71-2 used a 2" inlet. Get the hose that matches your pump.
The radiator nipple is a different size on the 70-older cars vs the 71-newer cars as well, so simply swapping the hose to fit the water pump will result in an incorrect diameter for the radiator end.
Since we're resurrecting old threads, it should be noted that the 1970-earlier cars have the larger 2" water pump fitting and 1.75" radiator fitting whereas the 1971-later vehicles have the smaller 1.75" water pump fitting and 1.5" radiator fitting.
Rocketdriver
July 23rd, 2016 08:09 PM
70 w-30
February 9th, 2016 06:05 PM
e.cast728
April 7th, 2014 04:14 AM
rustycragars
November 18th, 2009 01:21 AM
