Vacuum Diagram and parts identification
Old April 12th, 2018, 02:47 AM
kuseetha's Avatar
Dear friends,
Can you please help me identify these bits?
Is this VRV? Vacuum reducer valve?
Is this CCV? Canistor Control Valve?
Is this Can Purge Solenoid?
Is this Anti Diesel Solenoid?
Is this VDV?
Vac tank i guess..
Referred to this
kuseetha is offline
Old April 12th, 2018, 08:22 AM
jaunty75's Avatar
The big round ball in the second-last photo, which should not be sitting loosely like that but should be mounted to the passenger side inner fender or perhaps on the firewall, is the "VAC TANK" shown on the lower left in the diagram in your last photo. Notice that one of its two ports is connected to manifold vacuum. It provides a reservoir of vacuum to operate the various vent doors in your HVAC system. If it is not in good shape and properly hooked up, you won't be able to change the vents from which the air flows on your heating/AC system no matter where you put the selector lever (VENT, HEAT, etc.).
The other things you're pointing to in the other photos look like the various vacuum switches (VDV, etc) shown on the diagram. Hopefully your vacuum hoses are still connected to where they should be, and you should be able to use the diagram to trace them and figure out what's what. A factory service manual for the car would be very handy here.
jaunty75 is offline
Old April 12th, 2018, 05:53 PM
This is the VDV:
This is the CCV:
This is the Cannister Purge "Solenoid" (it is actually a thermally operated vacuum valve, not a real solenoid). FYI, yours is broken. There should be a cap on the top. I expect it leaks vacuum.
This is the anti-diesel solenoid:
This is the VRV (not the VDV). Yes, that open port is supposed to be open (originally there was a small foam filter over it, but the foam has long ago crumbled into dust).
joe_padavano is offline
Old April 12th, 2018, 06:26 PM
BillK's Avatar
Ha..... just finished replacing most of those on my Wife's 84 Riviera during my engine rebuild. Played heck finding them but managed to get all new NOS stuff from E-bay.
BillK is online now
Old April 12th, 2018, 09:49 PM
kuseetha's Avatar
Thank you so much friends. Got answers to all my questions!!
kuseetha is offline
DoubleV
July 25th, 2014 02:26 PM
Frankenstien
May 12th, 2011 01:57 PM
Giveuptheghost
December 23rd, 2007 06:28 PM
83 hurst
September 26th, 2007 03:20 AM
SX455
July 25th, 2007 05:03 PM
Quick Reply: Vacuum Diagram and parts identification
