Mistakenly Bought Diesel Motor Oil for Gas Engine
Changing oil on an Olds 350 engine with 140K miles on it. Usually use 10-W40 oil and it doesn't burn any.
Saw Shell Rotella SAE 15-W40 oil for $15 (4 gal) at Advance Auto and thought that looked like a good price. Bought a jug and got ready to pour it in and noticed it says for diesel engines.
Is there any reason not to use this oil in my gasoline engine?
John
John
Some folks intentionally use diesel oil because, sometimes, it has more of the old additives that have been removed from gas oils. There are arguments that diesel oil is friendlier to hydraulic flat tappet cams, but some folks say they have no benefit.
IMO, no worries. Just run it.
Diesel oil USED to have more zinc, which is why folks would run it in flat tappet motors. Unfortunately the EPA has caught up with diesels now and there is no longer a zinc benefit.
Plus most contain entirely too much detergent. Most cam companies have recommended against using them for years.
Generally used Valvoline or Pensoil 10W40. Last few times have added 5-6 oz STP based on it having some zinc. But oil pressure runs higher (60 psi) until engine gets warm (180 degrees) so probably going to leave the STP out this time.
Engine is carbed with no O2 sensor or catalytic converter.
Put about 2000 miles a year on the car, so change oil/filter once a year.
Since I hadn't opened the jug, I returned it today and got Valvoline 10W30 to try. If oil pressure runs under 40 psi hot I will add some STP.
John
John
John
John
What that man said.
The problem with "I've used X since new" oil thinking is that it's not the same oil.
There's very little new, good engineering under the sun. Most of it is "oh, we no longer need this feature, so removing it will allow this to happen" and you flat out bone anyone who still needs that feature. Most cars have roller cams, ergo the need for the additive is gone for those cars.
It would be an interesting lawsuit to see if you could hold an oil company responsible for flattening lobes. Cams are so cheap that it would never come to court.
I always use Rotella 15- 40 and the last time I checked on the zddp it was around 1,080 ppm on the scale. The zinc was why I started using Rotella but I haven't experienced any lifter sticking in 4 or 5 years I think the detergents keep the lifters cleaner than the oils I have used in the past. I know there are better oils for higher revving high compression engines but my ride seldom sees 4000 RPM and the compression is around 8 1/2 to 1 pretty mild. It works for me in the areas that I need help in.... Tedd
What that man said.
x3 with VR1
Very true
Most of the oil manufacturers market oil towards the older flat tappet engines, you just have to research carefully.
x3 with VR1
Very true
rotella
Fair point, but ideally they would end up on the oil pickup screen, or in the filter, or sludged up on the bottom of the pan. However, my point was that, even the cost of a rebuild included, no engine fix job will result in lawsuit territory.
phil tozer
August 3rd, 2011 11:54 AM
njot33
September 25th, 2009 09:07 AM
