in search of, olds engine builder
Hi to everyone. I've been following various threads for a few years now. Ever since I got a steal of a deal on a really sharp 72 350 Cutlass that no one wanted. Reason being , it's a 4dr. Yes , I know, nobody wants a 4dr, but ME. I just like the Sleeper looks.
Yes , that technically make me a NEWBIE. I need some of that ClassicOldsmobile hospitality. I'm looking for an Olds engine builder in my vicinity. I am in the Eau Claire, WI. area. I am actually 2+ hours East of the Twin Cities.
I have done several upgrades on my ride, all on the top end. But the last ones pushed it over the edge. Now I have an awesome ride that won't run.
Please Help I can give more info if.... anyone wants to know more.
Thank You, for the quick reply.
Yes, I know there are places in WI. I was hoping someone would kind enough to give some specific names of places they have dealt with.
The key word here was Vicinity. Not 2 to 4 hours away. I'm inquiring firsthand knowledge of someone right here in the Chippewa Valley area.
Thank You Gary. Are they fair and reasonable on price? I know prices are relative. But I've dropped 4 grand into her and She runs worse now than when I got her. One of those things where I should have listened to my wife. Leave it all stock original. But nooo , Lol, I wanted set-you-in-your-seat.
If you call them and tell them what you want they will work up an estimate. The parts are reasonable and it may take a day or two to call you back when they are real busy. I was looking for a boatload of HP on a 455 so only way to know your cost is call. They are easy to deal with so far. Others here will chime in if there is a closer option I guess.
Updates
Not sure where to start. Originally, I replaced the factory intake with a 2711.
the 2brl with an edelbrock 1405 w/electric choke.
distributor with a Pertronics 2 billet w/ Flamethrower 2 coil
ceramic coated 1 3/4" full length headers
MagnaFlow Dual 2 1/2" polished SS w/cross over
Custom SpeedHut gauges
It ran great. But I wanted more kick. So I decided to update again. 4000.oo later. Everything recommend by... after explaining what I wanted.
7111 Ported by Mondello
Ported by Mondello Edelbrock preloaded Heads 60519
Holley Avenger 870
Roller Rockers, push rods,
RV cam and lifters
True dbl roller timing chain. Everything from Mondello's . All top end. Nothing on the short block.
Break-in went great . Strated right up. Went straight 2k rpm and varied 2-3 k rpm for 20 minutes.
Here's where things go down hill.
Holley Avenger 870
RV cam and lifters
Now I have no compression, no vac. Backfires through to carb as soon as you touch the gas. I was told to keep advancing timing . 68* advanced Didn't help. After this going on for 8 months, it now won't even start. He told me to take everything off , go back to the 1st update. See if it runs. Really. Nope. I think the cam is wiped. Who knows what else.
Mondollar is your first problem, they should have known better but they are crooks. Unless those heads were milled to 50cc, your compression will be horrible, the 72 350 has 24cc dished pistons, not easy to get reasonable compression with them.
I think you can siassemble what you have. Note what you have and taylor build your own engine along with a machine shop that will be willing to do the machine work you need done to your ideal specs. It wont be a total loss that way.
You have a good top end to start with, now you just need the rest. If done right it'll be a very strong engine. Check out some of my builds on here. Let me know if I can help with parts selection etc. as well.
According to what they wrote on the Edelbrock box they were cut to .60 They sent me 3 sets of head gaskets. I was told to use the best one. I used to thickest one. I think now, I should have used the thinnest. Yes, I feel like and idiot.
As you have guessed , Yes I'm in need of help. Thank You for the offer. At this point it's find a machine shop. That is why I'm looking to see if there are any reputable shops in my area. I believe the cam is toast at this point. Would a roller cam be worth the extra cash??
My dilemma, Can I build up my 350 short block , get awesome torque and performance without putting another 4grand into her?
Or do I look for a 455 and try to use what I have purchased on it?
I do intend on going with an R series tranny and a 2000-2500 stall, at some point. When I have the funds. It is also a peg-leg right now.
I just want to get back on the road
Cutlassefi, I saw on one of your post a recommendation to do a olds 350 stroker.
Dumb question, can any olds 350 block be used or does it have to be the diesel 350 block? Is the cost payoff worth it?
Using the thicker gasket didn’t make more than a couple tenths difference in your compression ratio. Don’t sweat it.
And even if they did cut the heads .060 that still only leaves you with, at best, 8.5:1 compression. You need a full point more than that as well as the right cam and tune up to make a difference.
Pm me and we can discuss further if you like. Thanks.
