HEI distributor assembly
Dear friends,
Mine's a 87 307. I took off the distributor cleaned it.
When I was fixing it according to the chassis manual, it says I have to loosen and re-tighten the 3 screws (which are on the magnetic insulator plate) in such a way that the coil and the pole piece do not touch. (I mean the two spiked wheels, one that connected to the rotating shaft and the other one fixed by 3 screws)
I adjusted it many times this but I feel a slight click to my hand (8 clicks per complete revolution). Is this normal or is it still not adjusted?
Usually when I adjust a magnetic pickup I put a piece of newspaper between the two pieces and tighten it down. That way I can be sure I won't have contact but they are about as close as possible.
Hmm...that's a great tip. Hardly any space in between though. Should try to get a paper strip in between. Thank you. I will update the results soon.
If on that particular distributor one point is supposed to be closer than the others, then yes. If they are all supposed to be equal distance apart then you will have to use a feeler gauge to get them all set.
Inner and outer spikes hitting each other is out of the question, as they just bind and no rotation happens then.
The chassis manual doesn't say anything about one point closer than others or anything like that.
Wanted to know how a factory fitted dizzy feels like when you rotate the shaft at the bottom.
Whether it is just a purely smooth revolution (similar to ball bearing feel) or with slight taps felt to fingers when you rotate it.
Sorted!
Dear friends,
After many times of loosening screws, tapping the magnetic pickup and tightening each, finally managed to setup the rotor as described in the chassis manual. However, still the clicks are slightly audible but no binding whatsoever. Thank you for your comments. Hope this thread will help someone in future.
djchunter
March 17th, 2016 03:57 PM
joepenoso
June 4th, 2014 01:56 PM
