374 Stroker build
Old October 17th, 2017, 09:52 AM
cutlassefi's Avatar
374 Stroker build
Hey guys,
Did a Procomp headed 374 Small block yesterday. I'll post the dyno sheets but here are the specs;
4.125 DSS Racing forged piston
Scat 6.00" I beam rods
Base Procomp heads, no port or bowl work, 2.07/1.68.
Performer RPM with divider cut
Quick Fuel 735 VS carb 71/84 jets, (stock is 68/80). Reduced secondary HS air bleeds from 33 to 31.
9.5:1
Custom Lunati Hyd Roller, 223/231@.050 on a 112lsa
1.6 Stainless Roller rockers
5/16 .120 wall restricted pushrods
7qt. Canton deep pan
Melling HV pump with purple spring
330 crank stroked to 3.500
Internally balanced
Manifolds;
382hp/408tq
Headers;
411hp/430tq
Run on 89 octane with both exhaust systems blowing thru pipes and Magnaflow mufflers. Thanks!!
cutlassefi is online now
Old October 17th, 2017, 11:48 AM
jmcghee's Avatar
Stroker
Sounds like that would be perfect for my 64 convertible.
jmcghee is offline
Old October 17th, 2017, 01:24 PM
oldsmobiledave's Avatar
Nice build
Well played sir.
Cost to build?
oldsmobiledave is offline
Old October 17th, 2017, 01:37 PM
What's the lift on the cam?
oldcutlass is online now
Old October 17th, 2017, 02:03 PM
cutlassefi's Avatar
.547/.541 I believe.
9K+. Customer supplied valve covers and manifolds.
Old October 17th, 2017, 02:18 PM
cutlassefi's Avatar
Pics. Thanks.
Old October 17th, 2017, 02:30 PM
Red line
Curious why you stopped the pulls at 5500 rpm?
Old October 17th, 2017, 02:37 PM
cutlassefi's Avatar
I did one to 5700 with an air cleaner installed. It quit making power at 5500.
If you look at the header dyno sheet you'll see less than 1 hp difference between 5400 and 5500. That normally tells you it's pretty much done.
Thank you for the thumbs up btw.
Old October 17th, 2017, 07:33 PM
Oldcoyote's Avatar
I love these posts. What is the source of the stroker crank and have you ever put one in a 403?
thank you
Oldcoyote is offline
Old October 17th, 2017, 10:09 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
This is just an offset ground 330 crank according to Mark's list. Very nice street build. 30hp and tq with headers over manifolds.
olds 307 and 403 is offline
Old October 18th, 2017, 12:08 AM
fyi
29 hp & 22 TQ actually (not 30 & 30) but still shows the value of headers.
Old October 18th, 2017, 04:56 AM
cutlassefi's Avatar
Not so fast. At 5500 it's about 29lbft as well��
But yes it does show the value of headers. More power across the board with no loss anywhere.
Old October 18th, 2017, 02:10 PM
Rodney
cdrod's Avatar
Performer RPM divider cut?
Hey guys,
9.5:1
Internally balanced
Manifolds;
382hp/408tq
Headers;
411hp/430tq
Hey Mark:
Tell me about cutting the divider in the Performer manifold. What are the benefits? Does it help low-end or top-end performance. How much is removed? Thanks
Rodney
cdrod is offline
Old October 18th, 2017, 04:55 PM
cutlassefi's Avatar
Last time I did a back to back it was about 5-8hp above previous peak. It does not hurt it anywhere else.
I normally cut them 3/4"-1" depending on the depth of the plenum.
Old October 18th, 2017, 05:50 PM
Makes sense kind of like an x pipe for the exhaust, helps feed the cylinders more evenly.
Old October 21st, 2017, 06:44 AM
AZ520's Avatar
I just dropped off a 1972 olds 350 to my machinist, he is doing short block tear down and build if is buildable. It was a 150 dollar craigslist find. It still had the nylon timing gear, never been opened up. I have been reading about these stroker builds using small journal chevy rods and offset grind the crank to 3.5. I would love to get a 370 olds, but have a budget of about 2,000 for the short block.
AZ520 is offline
Old October 21st, 2017, 06:47 AM
AZ520's Avatar
Question
Is it possible or am I dreaming
AZ520 is offline
Old October 21st, 2017, 07:48 AM
The journals on the crank need offset ground and widened. Figure in that plus the cost of the 2" journal sbc rods and sbc 400 pistons. The rest will be normal machine work.
Old October 21st, 2017, 08:12 AM
ELY442's Avatar
That's a small cut. I see other manifolds that has a pre cut divider that has a larger cut than yours. Any benefits from that?
ELY442 is offline
Old October 21st, 2017, 11:49 AM
cutlassefi's Avatar
Dunno, never tested those back to back but I would imagine any cut at all would be beneficial.
Old October 21st, 2017, 02:59 PM
cutlassefi's Avatar
Final numbers. Both were done after running the temps up a bit. Thinner oil means more power.
415 is 1" Wilson 4 hole tapered spacer. 417 is 1" open spacer. Any idea why they didn't make much of a difference?
Thanks.
Doomah
June 3rd, 2016 08:26 AM
cutlassefi
February 21st, 2013 07:51 PM
TORTUS
October 18th, 2012 04:50 AM
cutlassefi
July 9th, 2012 09:34 PM
442 Jack
May 23rd, 2008 11:16 PM
Quick Reply: 374 Stroker build
