Olds 307 no spark
Old October 16th, 2017, 04:02 PM
Copper Nine Eight's Avatar
Olds 307 no spark
1985 olds delta 88 307
Spark plugs arent sparking. It cranks but wont cut on. Happened yesterday and randomly started running and stayed running. Happened again today but did not stay running. It ran for about 10 seconds.
what could be the problem? Thanks
Copper Nine Eight is offline
Old October 16th, 2017, 06:41 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Check cap and rotor to start. Make sure ghe center button on coil is also good. Resistance check the pick up coil and actual coil. Usually modules and coils just die. The pickbup coil can be flakey but can die out of the blue.
olds 307 and 403 is offline
Old October 17th, 2017, 02:36 AM
Make sure you have voltage to the batt terminal on the cap first.
oldcutlass is offline
Old October 17th, 2017, 04:00 AM
ctosiflying's Avatar
It’s probably the HEI Module at the bottom of the distributor. Replace it with dielectric grease between the module and distributor Body. It will start right up.
ctosiflying is offline
Old October 17th, 2017, 05:43 AM
Cap, rotor, coil, ignition module, power source, pretty much anything in the ignition system. Systematic troubleshooting (and NOT replacing parts randomly) is you friend. Start by testing to see if you have power at the wire going into the BATT terminal on the HEI when the key is in START and RUN positions.
joe_padavano is offline
mthompson1951
November 5th, 2016 12:27 PM
carbonf00tprint
November 4th, 2012 07:53 AM
stlregal
October 26th, 2010 08:45 AM
t/a formulas
February 23rd, 2010 06:36 PM
Quick Reply: Olds 307 no spark
