Problem after problem.
Yes, it is. Your switch pitch torque converter is commanded to the high stall speed position both at wide open throttle and at idle. The kickdown switch also activates the converter solenoid at W.O.T., but this switch on the dashpot is how it is activated at idle and low speeds. You need to rig some sort of microswitch to replace this part.
The Chassis Service Manual details the proper adjustment procedure for that switch and dashpot. Don't assume it is adjusted correctly at the moment.The fact that the intake is painted a non-original blue tells you it has been apart at some time in the past.
The factory manual was a five volume set. Get an original paper factory manual, NOT a reprint or electronic copy. There were no electronic originals, so any reprint or CD is a scan of an original, and detail always gets lost when that is done.
Arrowstorm
Suspension & Handling
25
July 29th, 2015 05:52 AM
kandelino
December 20th, 2010 12:54 PM
emarkay
December 8th, 2004 08:23 AM
