QJet Base Gasket
Old August 8th, 2017, 01:47 PM
tgilligan's Avatar
QJet Base Gasket
Greetings!
For a QJet 4 bbl carb on an Edelbrock Performer intake which has the spread bore, should I be using an adapter plate or just the thick Felpro base gasket? I'm using the Felpro now but am having a vacuum leak but think it's due to a bad gasket. Was wondering what others are doing?
tgilligan is offline
Old August 8th, 2017, 02:06 PM
Just a spread bore base gasket is all you need.
oldcutlass is online now
Old August 8th, 2017, 03:30 PM
Yes, just the spread bore gasket. I use the style with the hard plastic inserts at the boltholes so I don't over tighten it.
Fun71 is offline
Old August 9th, 2017, 06:36 AM
x2
They are reasonably priced as well. $10 maybe?
Olds64 is offline
JOHNNYOLDS442
November 18th, 2015 11:54 AM
fatgroundhog
June 14th, 2015 03:04 PM
JpMotorsports
March 26th, 2015 09:06 PM
bccan
October 30th, 2010 08:27 AM
cfair
June 11th, 2009 10:25 AM
Quick Reply: QJet Base Gasket
