high volume water pump
Old July 13th, 2017, 02:55 PM
Bill
1kool88's Avatar
Does anyone know where I can get a high volume water pump for a 1950 303ci?
Or,a place to build one.
Thanks, Bill
1kool88 is offline
Old July 13th, 2017, 04:44 PM
442Harv's Avatar
Check with Fusick, I think, they may rebuild, or have replacement ones.
442Harv is offline
Old July 13th, 2017, 08:47 PM
Ozzie's Avatar
Thanks, Bill
I don't know of any "high volume" water pumps for that application. Those original impellers had 6 vanes. I have seen pumps with a couple more vanes than the original (8 total), but I don't know if they qualified as "high volume". The ones I saw also had the larger bearing on them. They were intended for the later stage one engines equipped with A/C. I don't know where to get them. The GM part number for the pump for 1950 is 570355. The parts book shows only one impeller, part number 555795. Similarly, it shows only one overhaul kit (which includes the impeller), part number 569953.
The suggestion of Fusick is as good as I know, They have a rebuilt pump for $209 + $85 core + shipping; and a reproduction for $119 + shipping. You could ask them about the capacities.
Probably there are people around who could rebuild your pump, if they had the replacement seal and bearing. It's not a difficult job if you have the press. Before hurricane Katrina, New Orleans had one called Quality Reconditioning. It's now extinct.
Ozzie is offline
Old July 14th, 2017, 07:59 AM
Bill
1kool88's Avatar
Thank you guys. I appreciate the info. Bill
1kool88 is offline
dal442
June 25th, 2017 04:09 PM
Cpriester123
August 15th, 2016 08:46 AM
86pontiac
February 17th, 2010 11:24 AM
68conv455
December 26th, 2007 07:29 AM
Joel n
January 12th, 2007 03:34 PM
Quick Reply: high volume water pump
