engine stand bolt kit for 350
Old July 9th, 2017, 02:47 AM
crazymathlefou's Avatar
Hi US friends,
two days ago when i was tuning my carb, engine have stall. Impossible to crank on turn it with damper pulley. A friend have eared strange noise before engine stall. Maybe engined is damaged a connecting rod is breaked.
Don't worry about issue i'll make later another post about engine repair .
First,i have bought a rotative engine stand. But i don't have bolts for install the blog on the stand.
I have found a bolt kit on summit but it cost 6$ but ar least 50$ for sending it to france.
Another kits on ebay are less expensive.
Do you know if those bolts kit aviable on ebay have an universal size and thread ?
Best regards from france.
crazymathlefou is offline
Old July 9th, 2017, 07:33 AM
72 Olds CS
RetroRanger's Avatar
I don't know about the availability of SAE bolts sizes in France but the bolts you need are common here in the US. A local hardware store carried the bolts when I needed them no need to special order off eBay or summit. I don't know what sizes you need maybe someone else knows. FYI in the us there are many local stores that carry metric and SAE hardware for most homeowner type projects do you have similar stores in France?
RetroRanger is offline
Old July 9th, 2017, 07:41 AM
The thread size is 3/8-16, which is standard SAE coarse thread (UNC). Length will depend on the length of the tubes that they need to pass through on your engine stand. Use at least Grade 5, preferably Grade 8 to ensure the engine doesn't land on your toes.
joe_padavano is offline
Old July 10th, 2017, 10:09 AM
george landis's Avatar
engine stand bolts
Could you use 4 bolts off the engine. Say, intake or exhaust manifold bolts or bracket bolts? Just temporarily to get it mounted to the stand?
george landis is offline
Old July 10th, 2017, 10:13 AM
Not even close to the right length. Most engine stand heads have at least 2" tubes, so the bolts need to be almost 3" long. Not a lot of 3/8-16 bolts on an Olds engine that are that long.
Old July 10th, 2017, 10:57 AM
Kalle's Avatar
Hi.
Donīt buy all the nuts and Bolt in the US... waste of time and money.
I just bought threaded rods.. you can cut them to your desired lenght.
http://www.ebay.de/itm/1-Gewindestan...item5d4f0050bf
Dont buy the cheapest engine stand! Mine is rated for 1250 LBS... it looks scary if the engine is on it.
Kalle is offline
Old July 10th, 2017, 11:02 AM
Originally Posted by Kalle
Hi.
I don't know about that particular product, but most inexpensive threaded rod is low-strength. I would not trust my engine or toes to something like that without confirmation of the strength.
Old July 10th, 2017, 11:14 AM
Kalle's Avatar
this one is "A2-70" Stainless steel... itīs rated between 6.8 and 8.8 regular bolts.
But they have got normal bolts in different lenghts ,too.
Kalle is offline
Old July 10th, 2017, 03:36 PM
A2-70 is 304 SS and not very strong. The nuts will gall if stressed.
oldcutlass is offline
Old July 10th, 2017, 09:19 PM
bolts
Just trying to figure a way to use bolts he already has if access to SAE stuff is hard for him to get. Some of the alternator brackets and air conditioning brackets have some fairly long bolts. Just a thought.
chip-powell
November 5th, 2016 08:04 AM
cts-v
January 10th, 2009 06:20 PM
esisson
November 19th, 2008 10:40 AM
Jolly Green
April 2nd, 2008 01:04 PM
Green Machine
May 18th, 2006 12:28 PM
Quick Reply: engine stand bolt kit for 350
