Help with starting the car after it's warmed up
Old June 13th, 2017, 01:02 PM
Arctictoaster's Avatar
Hey guys new here.. so I have a 1972 cutlass supreme 5.7l 350. 2 door convertible. I have upgraded a good amount of things, the problem I am having is after the engine is warmed up. In the morning the car starts right up, after it reaches about 190 degree and I turn it off wait a few minutes try to turn it on again and it struggles. I replaced the thermostat with a 180.. any suggestions?
Arctictoaster is offline
Old June 13th, 2017, 01:47 PM
RROLDSX's Avatar
Does the motor turn over normally and it just won't start or does it turn over slowly?
RROLDSX is offline
Old June 13th, 2017, 07:48 PM
What do you mean by "it struggles"?
Are you cranking it while holding the throttle slightly open?
Is the yellow wire from the starter R terminal to the Coil (+) terminal connected?
Welcome to ClassicOlds.
MDchanic is offline
Old June 13th, 2017, 08:34 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Those Edelbrock carbs, much like factory AFB carbs are known for hot start issues. The fuel boils in the carb, a phonelic spacer or better yet a Qjet or Street Demon carb will fix it right up.
olds 307 and 403 is offline
Old June 14th, 2017, 08:11 AM
Olds Fever
CRUZN 66's Avatar
Welcome to the group... Possibility the choke is not opening all the way or not staying open after it is warmed up and you shut it off... On the restart, if the engine is warmed up, and choke is closed (or partially closed) starting can be difficult...
CRUZN 66 is offline
Old June 14th, 2017, 10:12 AM
Mr. Johnson
rjohnson442's Avatar
Welcome!
After its warmed up take the air filter off and the have someone shut the car off. Do you see fuel still pouring down into the intake? We need to rule out fuel related problems vs electrical problems.
rjohnson442 is offline
Jonmueller1
December 20th, 2013 07:27 AM
gearheads78
March 29th, 2012 08:08 AM
mhartley
June 7th, 2011 08:25 AM
BlueCalais79
May 4th, 2011 03:10 PM
tinner
March 24th, 2011 03:44 PM
Quick Reply: Help with starting the car after it's warmed up
