Stuck throttle plates
Dear Friends,
I took off the CCC Qjet of my 307 and the throttle plates are totally stuck with black gunk. I have cleaned one side and left the other to contrast. I tried to rotate the two levers (shown in the other picture in red arrows) hoping to make these plates to rotate but they won't budge. Sprayed WD40 and carb cleaner but still no use.
Is there anything else that could be holding them? What should I do?
Note: Car idled without any hesitation when I started it after about 3 years. But when I stepped on the accelerator pedal, it didn't rev or move down as expected.
Dear Friends,
It doesn't look like your linkage is binding. I suggest soaking it in cleaner for at least a week and then coming back to it. Pine-Sol is a good alternative to caustic cleaners like carburetor cleaner, diesel fuel or kerosene.
You do realize that the secondary throttle shaft (the RH lever in your second photo) has a lockout to prevent it from opening unless the choke is fully open, right? This lockout lever uses gravity for alignment and if the carb is not held in the correct position, it may lock the shaft at all times.
The choke is definitely not open so I might have to look in to it with regard to the secondaries. The primaries are definitely stuck with gunk then.
When nothing is moving, it is kind of difficult to figure out how things are supposed to move. (never seen these before for real)
Thank you for all the comments I will post the results soon
I disconnected the rubber hoses (incoming and return lines) below the fuel pump where it connects to metal lines and immersed those in a can of gasoline. And then I started the car.
As Joe said, the choke which should be on will prevent the secondary plates opening. But the primary plates should still open right up. If you push down on the fast idle cam and open the throttle, all four should move. I would say moisture must have sneaked in while sitting. It doesn't look extensive, must be just enough to freeze the plates.As said some light tapping should do it. Shoot WD-40 in the sides of shafts as well.
The computer-controlled Qjet requires careful attention to the tuning process to get it to run correctly. You MUST read and follow the adjustment process in the Chassis Service Manual EXACTLY. Failure to do so will result in a poorly-running car and a dissatisfied owner. Be sure every single vacuum hose is in good shape and connected correctly.
Like mentioned, check that secondary lock out.
Most of them we get in with frozen shafts are heavy with corrosion and rust. Yours actually looks pretty clean to be frozen shut.
Remove the base plate from the carb body and soak it good.
We remove all the throttle blades and work shafts loose with heat and lubrication when they are severely stuck.
Done!!!
Hi friends,
Hope this will be helpful to anyone encounter this problem in the future.
I manned up and removed the 3 torx nuts at the bottom and the two longer ones at the top and took off the lower plate that has the 4 throttles.
Immersed it in kerosene over a week, but didn't help.
Sprayed WD40 to the shafts in the morning, rotated and sprayed in the night for a week.
Finally kept it on the kitchen gas stove and heated it and left to cool till morning.
Again WD40 treatment for 2 days. Finally it started to move!!
Rotating the throttle plates gave a small sand crunching noise so sprayed a lot of carb cleaner on the shafts. Lots of black residue dripped down and now it moves all good.
Cleaned the outside of the carby with patrol and fixed the vacuum things (what do you call them?) after testing with the vacuum gauge.
Finally sprayed WD40 Silicon to the external shafts and now things look good.
A big thanks to all the valuable comments.
sqeeek
March 14th, 2017 10:35 AM
