72 fan hits lower shroud
Old April 28th, 2017, 10:35 AM
Cory
dream66's Avatar
72 with stock SBO and fan hits shroud intermittently on the bottom of the shroud.
Appears to be correct shroud and fan,
Core support mounts are correct height
Motor mounts look relatively new
Not sure if correct tranny mount is installed.
Could the motor mounts be BBO and dropping the engine lower?
Could the Tranny mount be too tall?
I can't imagine that the front crossmember has sagged but I suppose it's possible.
Sorry for the ignorance but I'm predominantly an A-body Chevelle guy and the Cutlass is one different animal.
dream66 is offline
Old April 28th, 2017, 12:54 PM
Could be the radiator top plate is too high. Any idea if the car has the original or correct height radiator? I had that happen before, and when the two top shroud bolts were tightened the shroud would pull up and cause slight contact at the bottom. Loosening the bolts some and adding spacers between the shroud and top plate cured it. Well, a correct height radiator was the real cure, but the spacers alleviated the immediate problem.
Fun71 is offline
Old April 28th, 2017, 01:25 PM
72 Olds CS
RetroRanger's Avatar
mine rubbed w sacked motor mounts, new motor mounts and no problems
RetroRanger is offline
Old April 28th, 2017, 02:18 PM
Make sure the shroud is fitted correctly. As stated motor mounts may be sagging. I'll add check water pump and clutch fan bearings,
oldcutlass is online now
Old April 28th, 2017, 02:25 PM
Cory
dream66's Avatar
Could very well be the incorrect radiator - I'll put a tape measure on it.
dream66 is offline
Old April 28th, 2017, 03:49 PM
68442's Avatar
Do you have the correct fan? Olds had a 19" and a 19 1/2:" in those years.
My 72 did the same thing with a 19 1/2". Went to the 19" solved the problem
68442 is offline
Old April 28th, 2017, 06:24 PM
Cory
dream66's Avatar
I have a spare 19" somewhere. I'll check what's on it now
dream66 is offline
Old April 29th, 2017, 01:57 AM
svnt442's Avatar
BBO or SBO mounts position the crank center line in the exact same position in the frame. The bottom of all modern olds V8 engines are of the same dimensions and can interchange mounts.
What this means is where one was bolted up, any other modern olds V8 will bolt up with the same mounts and be in the exact same position in the frame.
So, no.
svnt442 is offline
Old April 29th, 2017, 10:14 AM
If you could have forced the 2328 rubber motor mounts into place with the frame mounts for the 2261s, the engine would sit an inch HIGHER than stock. You can't go any lower - the oil pan would hit the crossmember.
Possible. Also, check the frame rails where the crossmember bolts up for deformation. I've had cars that were incorrectly jacked under the open section of the frame, causing the lower flange to be bent upward and raising the rear of the trans.
It really isn't. That's about the stiffest and beefiest part of the whole frame.
joe_padavano is offline
Old April 29th, 2017, 10:29 AM
joesw31's Avatar
In 1971 and 1972 they used a different fan shroud to accommodate the larger 19.5 fan blade. It could be that your fan shroud needs adjustment.
joesw31 is offline
Old April 29th, 2017, 12:30 PM
And to expand on this, 69-70 used P/N 402995. 71-72 with A/C or HD cooling used P/N 407867.
Old April 29th, 2017, 09:19 PM
Cory
dream66's Avatar
First...Let me thank you all for your trouble shooting tips. I've made some progress.
I loosened both lower shroud mounts and re-positioned the shroud to the pax side a bit. Also, one of the lower tabs that the shroud is attached to was bent to the driver side slightly and I bent it back vertical.
I also straightened up the lower pan of the core support as it was slightly bowed upward. There is NO WAY I can see that the shroud can be lowered further, even by using shorter rubber core support mounts without the fenders drooping in front.
I still need to check the radiator top plate. I suspect it's not original because it has the VIN "K" Emissions spec sticker and the car is VIN "H"
The fan is 19" and the clutch/fan mounting is secure.
I'll check the dimensions on the fan shroud to determine which one I have
These steps provided enough clearance so that the fan doesn't hit the shroud but I still have 1 1/2" clearance at the top and only 1/2" at the bottom.
The Tranny crossmember looks to be correct - not bent - and the frame rails are not bent at the crossmember attach points.
One thing I did notice which I've never seen on a GM "A" body: When turning the wheels full right to the stop - the driver side frame horn twisted outward about 1/8" - enough to shift the core support and shroud so that the fan started rubbing. I found no buckling or evidence of a prior collision and no cracks.
dream66 is offline
Old April 30th, 2017, 05:09 AM
I noticed on a previous post you did some frame tweaking, this might have been a contributing factor.
Old April 30th, 2017, 05:29 AM
Cory
dream66's Avatar
The fan shroud issue existed before that, so no.
dream66 is offline
Old April 30th, 2017, 06:51 AM
Cory
dream66's Avatar
Found this diagram on ebay. The shroud DOES REQUIRE spacers/shims below the top plate. I have plenty body shims so I'll check my top plate.
dream66 is offline
Old April 30th, 2017, 04:31 PM
High 11s's Avatar
I had the same issue on my 1970 442. It only occurred when the engine was first started from cold...once warmed up it was fine. Eventually I spotted rubbing marks inside the fan shroud at the bottom. I ended up adding shims per your post above (and per the service manual) and slightly the lower cowl mounts. Problem solved! I checked the shroud, fan, clutch etc and all were correct for the car.
Hope that helps.
High 11s is online now
Bee Saint Louis
July 5th, 2019 08:58 PM
shamusj
January 13th, 2015 05:44 AM
Mark71
June 26th, 2011 06:01 PM
phukinartie
October 30th, 2010 12:42 PM
Quick Reply: 72 fan hits lower shroud
