Wrong cam for my application?
#41
You have a cam that needs more compression, so you need new pistons.
Or, you have pistons (low compression) that need less cam, so you could go to a RV cam (204/214). I've never rebuilt an engine, but isn't a cam change a lot cheaper and less work than replacing pistons?
In either case, a numerically higher rear gear (3.42-3.90) will add a lot of pep and makes a really nice street driver when mated to an overdrive transmission (TH2004r or 700R4). The overdrive gear is 0.70 I think and will keep highway cruising rpms in the 1800-2200 range with the higher gear ratio.
My street rod has a stock 1971 Olds 350 with an RV cam, Street Demon 625 carb, 3.42 rear, and TH2004R transmission. The engine has 146K miles on it with the original pistons, rings, bearings, and heads -- never opened up. Lucky I guess to still be reliable with no engine noise, no smoke, no oil useage, and get 18-20 mpg.
Stock 4 bbl in 1971 was rated 180 hp I think (rated by today's standards). Maybe it is a little over 200 hp now with the minor improvements and dual exhaust. Its not a barn burner but will lay short dual strips of rubber with posi rear.
If you really want to do an engine rebuild, my choice would be the higher compression pistons, but you can have a peppy car with the stock pistons, RV cam, steeper rear gear, and overdrive transmission.
John
John
#42
John
John
#43
Yes, a 3 barrel to fit on square and spreadbore manifolds. Any carb will need to calibrated to YOUR motor. The Qjet, Street Demon and AVS all have the air velocity secondaries, making it much harder to over carb. Plus both have multi step metering rods, like your Edelbrock and triple stacked primary boosters, unlike your Edelbrock. The 625 cfm is fine if you never plan to run above say 4500-5000 rpm, if you want more like 5500-6000 rpm, the 750 will be better suited. I would buy a calibration kit for either. Good luck getting rid of the stumble on that Edelbrock, some have tried everything with no luck.
#44
You will need to change or modify your driveshaft and your forward emergency brake cables.
#45
I am in the middle of a 2004R swap right now. As said above the cross member will work, just move it back and the drive shaft SHOULD also work. I have swapped back and forth between a TH250C and 2004R on my G body. The emergency brake cable will have to be changed to a TH400 cable and or creatively modified.
#46
A stock '71 Olds with a nominal 8.5:1 compression ratio should have about 130psi in each cylinder, with a variation no more than +/- 10%, but as low as about 110psi would not be out of place on a used engine.
With that cam, it may be lower, but I can't say how much.
https://www.summitracing.com/int/par...ake/oldsmobile
#47
#48
#49
..till now , for the street engines i only use the EDE´s (hey they work and they simply) – but I have massive problems with the EDE 600 & 750 carb in a fresh mild built 403 that won’t run (it idle too high and runs like **** ....thinking about to use the street avenger carb, what you thinking about ?
#50
The 200-4R does sound like a very worthwhile swap for my build though.
Is there any advantage to sticking with my TH350?
#51
You can modify the cable routing by fabricating a shorter take up rod that hooks on the passenger side. Then use the adjuster for proper cable tension. I did this on mine when I converted to a T400.
#52
Does anyone want to talk me into a particular carburetor for this build? My buddy wants to buy my Eddy after I rebuild it. I like the Street Demon, but what makes it any better than a different option. How does one normally go about choosing a particular design?
#53
My stock 1971 (except for 204/214 cam) has cylinder pressures of 150-160 psi. Use 87 octane gas, HEI, 16 initial timing, 20 mechanical all in by 3000 rpm, 12 vacuum advance on manifold vac.
John
#55
#56
I then saw an ad for the Street Demon line that came out in 2012, owned by Holley. It has smaller primary throttle bores and then the larger "goggle" shaped secondary. Although not as "sophisticated" as the venerable QJet I bought the advertising that the smaller primaries provided crisp throttle response and good gas mileage like a QJet. Also it seemed to be a new simpler design. I also liked the sound of larger secondaries opening up, and online reviews on Amazon and Summit were overwhelmingly positive - this was a big influence on me.
It will mount on either a square bore or spread bore intake manifold. Some people have had issues with air cleaner clearance and throttle linkage interferrence with the EGR boss on some intakes. I did have a clearance problem between the throttle linkage and the EGR boss on my Edelbrock Performer intake manifold. Had to use a 1.25 inch spacer under the carb. I don't use EGR but didn't know better when I bought the intake with EGR.
After going to leaner primary rods and jets on the Street Demon (my engine is mild - near stock) I am happy with performance (improved a little over the QJet) and gas mileage (about same as QJet).
From what I gather, unless you have a high reving SB or a BB, you don't need more than a 600+ cfm carb.
John
1965F85_scholten
October 11th, 2013 05:49 AM
