Cam washer?
Old April 13th, 2017, 09:14 AM
330jetstar's Avatar
Cam washer?
I installed the new cam and timing set in my 330 last night after remachining of the block . The bolt head that holds the cam in seems small for the size of the cam gear. Is there supposed to be a washer. I know it's not a big deal I can just a washer. Wondering if I am missing a factory component.
330jetstar is offline
Old April 13th, 2017, 11:21 AM
The bolt holds the fuel pump eccentric on the camshaft. No need for any additional washers.
https://classicoldsmobile.com/forums...iming-set.html
Fun71 is online now
Old April 13th, 2017, 11:34 AM
jensenracing77's Avatar
You need to put a strait edge across the front rails of the block and measure how much clearance there is between the bolt and the front cover. If you go to much the bolt will hit the front cover. Don't forget that there is a gasket thickness between the cover and block
jensenracing77 is online now
Old April 13th, 2017, 12:03 PM
330jetstar's Avatar
D'oh I feel like a dummy yes that's all it would be is the fuel pump eccentric. Oh boy.
Old April 13th, 2017, 07:37 PM
Cutlass Fan's Avatar
Good thing you asked your question. It would have sucked to get it all assembled and find out you forgot the eccentric.
Cutlass Fan is offline
joesw31
January 16th, 2017 08:01 AM
grmchne78
June 25th, 2015 06:23 PM
Oldsmaniac
June 20th, 2014 05:44 AM
Uncle Hulka
March 12th, 2014 03:41 PM
57teebyrd
December 21st, 2006 07:07 AM
Quick Reply: Cam washer?
