olds 350 crank but not start
#41
#42
That timing sets should work. Get this set to seal it back up. https://www.summitracing.com/parts/FEL-CS8171-2 That nylon coated timing set is about the only reason an Olds 350 needs pulled apart after some miles and years. The timing cover can be a pain to put back in, the lower seal will need trimmed on the cover. Hopefully the Edelbrock carb will work OK, many have issues with them. It will no doubt be too rich for that motor.
#52
#53
#54
At first I though you were talking about the dipstick tube. How the heck do you even break the oil fill tube like that???
#56
I'm curious as well.
#57
time for rebuilding all now.
for checking if oil pan are dirty, i'll relive it.
i notice the water pump have only one hose out.
the water tank is only plugged on the radiator. he is empty.
do you know if the water tank is usefull ?
jensenracing77
May 29th, 2015 01:20 PM
garyfoust
November 25th, 2012 04:32 PM
