Choke Thermal Vacuum Switch
Old April 7th, 2017, 07:35 PM
77ricbaez's Avatar
Anyone know where I can find this part along with the vacuum ports and lines? I broke it and no stores seem to have it in stock; I doubt any junk yards will have any spare 70s-80s era GM's. It's all hondas and toyotas around here.
77ricbaez is offline
Old April 7th, 2017, 08:17 PM
I have never heard of a thermal vacuum switch for the choke. Those are generally used for the distributor vacuum advance. You'll need to find a part from a donor car as those are not reproduced.
Fun71 is offline
Old April 7th, 2017, 09:46 PM
77ricbaez's Avatar
Yeah, this thing is attached to the air cleaner ( i think it may be called the MAP sensor but im not sure) one line goes to the TACS and the other two connect to the rear vacuum break of the carburetor and a source of manifold vacuum.
Old April 8th, 2017, 12:42 AM
The bottom of that really looks like a temperature sensor that would go into a coolant passage in the intake manifold. MAP sensor would go into an intake runner on a TBI or EFI system.
Fun71 is offline
Old April 8th, 2017, 04:51 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
You could try high temp epoxy. Yah, I recognize that piece but don't think I have a spare. Pretty sure it was used till the end of Olds V8 production, so it should be at any yard that still has 80's cars.
olds 307 and 403 is offline
Old April 8th, 2017, 05:35 AM
Old School Olds
tru-blue 442's Avatar
Is this it? P/N 05266.
tru-blue 442 is offline
Old April 8th, 2017, 06:14 AM
Yes. The part is called a Choke Vacuum Break TVS and was only used on the 1977-1981 cars. Once CCC was introduced, this part was replaced by a solenoid valve controlled by the ECU. You are very unlikely to find a new one.
joe_padavano is offline
Old April 8th, 2017, 10:17 AM
77ricbaez's Avatar
yeah that's it. I just crazy glued the broken parts, hopefully it holds up it not I'm gonna have to epoxy it.
Old April 8th, 2017, 11:26 AM
Old School Olds
No problem, just shoot me a PM if you decide that you need it.
rcktdoc
December 13th, 2016 03:35 AM
Dead Reckon
Non-Olds Engines
December 7th, 2014 02:55 PM
jerseyjoe
November 2nd, 2014 02:22 PM
bornwina
March 24th, 2013 04:21 PM
Rob delta
January 31st, 2012 02:43 PM
Quick Reply: Choke Thermal Vacuum Switch
