Pistons search 215 '63
Hi, you can help-me to find the pistons +0.30 for my '63 F85?
Is possible find them??? where? (on Rockauto there aren't...)
is a 4bbl motor with this piston in pictures:
Thanks!
Thanks!
Egge machine shows them. Their products are pretty decent.
https://egge.com/product/kits.php?ac...engine=215+CID
I know Egge Makes them but I do not see them on there site. I got mine through D&D aluminum V8 http://aluminumv8.com/ for our car. I had to go .030 on ours also.
EDIT... I see them now. Has a drop down window for the size.
Thanks!
The pistons in the pictures of Egge site is not similar to my piston...
now I have write at D&D-aluminumV8...
I saw that the 215 has been installed on many cars in the years '60-'70-'80... (Rover)... you think is possible adapt an other 215 engine in my F85? which?? (if I find one in Europe!)
Thanks!
Thanks Joe!
For the 4.0 or 4.6 I am not interested
Therefore I can swap the entire 215 Rover engine (any year?), and he will mount perfectly on my Hydramatic? The intake and exaust manifold I can mount those of my olds 215?
There are not some changes or modifications?
...I ask so that I can evaluate if buy parts in USA ( + work here for rectification block) for redbuild my engine, OR find a 215 rover (parts or already mounted) here in Italy or Europe!
Thanks Joe!
[QUOTE=Ste981;994212]Thanks!
QUOTE]
The Egge pistons should work fine. They have a slightly different design with the 4 valve reliefs but that really should not affect anything. The compression ratio might end up slightly different but I doubt it would be noticeable in any way.
QUOTE]
An early Rover 3500 is nearly identical to the Buick version of the 215. All motor mount, bellhousing, and manifold bolt locations are exactly the same. You need to use the Oldsmobile flywheel due to the unique Rotohydramatic 5 trans. The only thing I'm not entirely sure of is if the Rover motors have all the same mounting provisions for the accessory brackets.
as regards the compression, I read some documentation on web, but I do not know exactly if my engine is 155hp (export?) or 185hp or 195/215hp and relative compression: 8.75 or 10.25 or 10.75 (my engine is 4 bbl carburator)
Furthermore, If I will buy a new parts for rebuild my engine, what is the right camshaft for my '63 engine? (I see that there are camshaft with different angles...)
Thanks for the help!
in your opinion, the heads of my olds 215 that are good (6 bolt for cyl.), mount on european rover 215? I will problem with compression?
For compression and HP.. you know what I have?
the block code is S(serial number)H and is 4bbl
in some documents for code SH I have seen 155hp (but 2 bbl), in other 185 or 215 hp and related comprssion 8.75, 10.25
Posted on this site by another member: https://london.craigslist.co.uk/ptd/6001725731.html
There is a concern that this might be a fraudulent ad. https://classicoldsmobile.com/forums...4&goto=newpost
Hello,
I have problems to find the pistons (and rings) +0.20
Egge.com have out of stock the pistons and will not have any till August
D&D aluminum-V8 replied to me that can not provide me the parts
All the rest would find on Rockauto, but where I can get the pistons for my 215??
Hello,
I ended up sourcing Buick dished pistons for my Olds 215 as they are still very common. My Jetfire needs it's compression lowered a bit anyway. By the time I resurface the heads and re deck the block, I'm sure my compression ratio will still be in the low 9's.
The Buick pistons with rings are on ebay for about $320 US. Last time I checked, there was still a 2bbl and 4bbl option available.
Hello, can you tell me the difference between these two series of pistons??
if Olds (as opposed to Buick) for compression changed the heads, and pistons were always the same, because there are pistons 4-bbl and pistons 2-bbl?
If 2-bbl work well on my engine 4-bbl, it would cost a lot less....
PISTONS KIT 2-bbl:
http://www.ebay.com/itm/Oldsmobile-F...aoioXrf4TB1zBw
PISTONS KIT 4-bbl:
http://www.ebay.com/itm/190289370880...%3AMEBIDX%3AIT
(the seller does not answer me)
PISTONS KIT 2-bbl:
PISTONS KIT 4-bbl:
PISTONS KIT 2-bbl:
PISTONS KIT 4-bbl:
PISTONS KIT 2-bbl:
PISTONS KIT 4-bbl:
The listings I'm referring to are not these. The listings I refer to are by a seller "old.parts".
Do an ebay search for "Pistons and Rings 61 62 63 Buick Skylark 215 with 4 bbl." (I'm lousy with cut and paste)
The difference is the dish depth on the Buick version between 2 bbl and 4 bbl pistons. I corresponded with him and if I recall correctly, he told me the difference in dish depth and or volume. From there, you can do your own calculations to fit your needs.
