Should I keep the 307 or uprgrade to 350
Just found out that the 1980 Cutlass that I have is a 307,should I keep it or get a 350.Thanks
Oh another thing any suggestions on this car would be great far as headers,exhaust,intake,etc.
And a good place to get some parts would be very helpful.
Go to the 350. Eveything on your 307 will bolt up to the 350 also. 307 isn't worth upgrading
Get new motor mounts for your 1980 Cutlass, not the kind of car the 350 comes out of. All SBO are externally the same
Easy swap
Easy swap
x5 on the 350. Look for an 72 or earlier engine, or at least early heads. The chamber size on 73 and latter heads got huge and will result in a poor compression ratio.
why not go with a 455. it's only a little more money to build.
iirc a 455 will drop right in. you need to get the engine with the accessory brackets , the exhaust manifolds and the crossover pipe as they are different. Im sure someone will chime in on which headers would fit the best. Also if you run headers on either engine you will probally need a double hump crossmember. summit and others have them
As long as the car runs and drives, use what you got. When the pup finally give up the ghost...Thats another story. There is nothing wrong with a small engine in a daily driver, done right a 350 will outperform a 307 any day probably with better economy. the only 307 I've ever ran was an odd duck Chevy, and that info came from the previous owner of an early '70's truck, I never confirmed it.
After looking at the pics, I'm guessing that unit is a project already, if so then I recant last post and vote 350 or 403 if you can find one. Nice ride don't see too many of those around here anymore.
Kidcutty
July 13th, 2010 05:06 PM
