Power wash = no start
I had the brilliant idea of washing off the oil from a valve cover leak I fixed. Engine was running great before. I thought I was careful and only did around valve covers and lower. Let dry. Now car won’t start and starter cuts out at times. On one attempt pretty good backfire. It seems to just crank and crank ,like it’s out of gas but it’s not. Any thoughts from the experts. My only thought is let is sit overnight and try again. ???
Thanks in advance
Thanks in advance
You can still pressure wash your engine. Just be careful where you spray and cover dist cap, coil, carb, alternator, anything like that that moisture might bother it.
Plus a clean underhood is so much nicer to work on...
Fun fact: WD stands for water displacement. It's completely non-conductive and was originally designed to displace water from electrical components for immediate use rather than having to wait for them to dry. I think the 40 is the number of formulas they went through to get it right.
All that science and we act like it's just for squeaky door hinges.
A salesman at an appliance store actually recommended it for stainless steel. It is the best thing I have found for the front of my kitchen appliances. There is an odor but it dissipates quickly.
Why not?
I use it to dissolve and remove tar and road oil before washing a vehicle. Everyone has a can of WD40 and saves having to buy a can of tar remover at yer FLAPS. Or do they even make that anymore?
