oil pump gasket ?
I only know my '71 350 and it didn't use one, '69 is probably the same but wait for a more positive answer before you go doing anything.
The oil that would leak from there if it did would would just go back into the oil pan anyway.
Location: from Wisc, then Texas, then Kansas, now back to Texas,
well, there is no gasket in the rebuild set, and I don't see any remnents of an old one,and I'm thinkin there was no gasket., but, IF it was to leak ,,I would think it would lower the oil pressure . just want to be SURE before I put the pan on .........thanks
'69 350, does the oil pump mounting to the block have a gasket ?
I talked to Mondello about this last year and he sold me a baffle plate that goes in between the oil pump and engine block. I also bought ARP studs for the oil pump as well.
The oil pump does not mount to the block, it mounts to the rear main cap.
The oil filter adapter mounts to the block and it does use a gasket.
Please read all the posts of this thread starting at the top.
Al2011
November 20th, 2013 07:15 AM
dallasite21
June 20th, 2010 05:37 AM
