High idle and other problems
So jist got my 84 307 running. New holley intake and holley carb that got a rebuild. No ccc. She starts but idles high, runs kinda rough, stalls when I start to hit the gas in drive. Is really hard to get to stay running in reverse. The rear float isn't adjusting quite right but seems to be about right. Vacuum lines look good but there's always chance I missed something to plug off. She stalled on a turn going into work today (risk it for the biscuit I wanted to drive it) started back up. It'll almost idle at 50 as it is. When I'm at a stop it's trying to drive through the brakes. I'm sure some tinkering will fix it but while I'm at work I can only look at it. Anyone have some ideas to test out? I plan on. Tapping on the bowl and seeing it I can free up a float that could be stuck, I plan on decreasing the timing which I think is at 24-26 degrees. I'll add the idle screw is all the way out, not even touching the throttle. Everything I've done has been new to me and I took a car that was rotten and brought it back to running and driving, replacing almost everything I touched. Holley carbs are new to me so I could be missing something stupid. Any help is appreciated.
A Street Dominator isn't a great choice for a stock 8 to 1 307. Who knows how that Holley is jetted, probably rich for a 307. Does it have a choke? As said, the distributor needs changed to a vacuum advance model. You will have no advance with the CCC distributor over where you set the base timing. Even if it has been changed, you need know the curve where to set base timing.
