Help identify Quadrajet
I found a Quadrajet carb in the trunk of a car I bought and can’t figure out what its for, any help?
17083253
1173 FLC
thanks in advance!
Dale Moody
17083253
1173 FLC
thanks in advance!
Dale Moody
Well, most of the time they get it correct - sometimes the information is a bit generic, but a fast Google search demonstrates it was employed 86-90 on Chev BOP 305/307.
https://www.carburetion.com/CarbNumb...umber=17083253
This would apparently not be one of those times.
17083253 is for a 1983 Oldsmobile 307 with CCC only. The carbs on the Chevy 305 were similar but used a side inlet, not a front inlet. Chevy carbs of that vintage end in numbers like 206, 208, 210. The "1708" indicates the decade of the 1980s. The "3" indicates the specific year (1983). The "253" indicates the application (Oldsmobile 307 with CCC). The CCC carbs of the 1980s were similar but not identical nor even swappable from year-to-year. The big difference (aside from metering rods) is the two-point vs three-point adjustment on the mixture control solenoid armature.
2blu442
December 30th, 2013 03:53 PM
79Cutlass805
January 16th, 2013 12:25 PM
