Heater control valve vacuum routing
Heater control valve vacuum routing 1972 cutlass supreme 350
Hello! Can someone point out where the heater control valve vacuum line should be routed in my 1972 cutlass supreme 350? I don't see it in the chassis manual. There is A port on the manifold directly in front of the distributor cap, but I believe that is where the plastic cylinder vacuum canister on the firewall, that's directly connected to the heater controls inside the car, is connected. Should there be a T here for both units to attach to that port on the manifold? Thank you! Chris
J-(Chicago)
October 10th, 2010 04:08 PM
