Best Inake a carb for 350
Hi All,
Planning on swapping my factory 2 Barrel carb and intake.What is the best intake aftermarket and carb to use or is it better to go with the factory 4 Barrel setup.The engine is completely stock with 57000 miles.
Cheers,
Keith
Cheers,
Keith
A Qjet with a factory 350 calibration and iron intake from the year of your motor. You can also go Performer if you plan on leaving it basically stock. The Performer RPM intake is better if planning upgrades. A Street Demon 625 or Quickfuel 600 Slayer in aftermarket if staying stock and either in a 750 if planning upgrades. All the aftermarket carbs will need calibration to your motor.
Thanks for the replies.
Completely stock with Turbo 350 Trans and original highway 275 gears.Car is just used to attend a few shows around close by and the occasional sunday drive.I want to keep the stock look.
Keith
Keith
I can only assume you are looking for a little extra oomph. My advice is proceed with caution and be very thorough following trough with all your moves.
