Bad Pulley or Bad Shaft on Power Steering?
Hello!
The pulley on my 1967 Cutlass Supreme w/ 330 V8 started rattling and became loose on the P/S shaft. I removed it and I am trying to figure out if:
A. It is the pulley, shaft, or pump that has gone bad
B. Where to find a replacement single thread pulley (if thats what it is)
C. Why the pulley went bad.
Here are a few photos for reference.
Number on pulley is 382418J0
First time posting! Super excited to see that this community exists.
Its looking like the woodruff key is missing completely. Are those standard to replace? Any particularly reason it fell out? Also, there is nothing between the pulley and the pump. Should there be a washer/bearing/spacer?
Hello again.
I put the pump back together with a new woodruff key but, alas, the pulley is still lose and rattling which leads me to believe the pulley is stripped out. Does anyone know where to find those sort of pulleys? They appear to be hard to find.
By the way, the photos in your first post are too small to tell any of this.
The pulley can be rocked on the shaft with belt on. When I pulled it apart the key was missing, leading me to think it was sheared off. Though minimal, there were some metal shavings on the shaft and pulley. So, yes, I do think one or both may have been worn out. The nut is tight, though I've read that on these pumps the nut isn't supposed to be what tightens the pulley down.
Also, all that is on the shaft is the pulley and nut (no washers, spacers, etc..) Is something missing there?
Really appreciate the help!
70convert
Drivetrain/Differentials
March 7th, 2019 02:12 PM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
