68 Supreme running issue
I have a 68 Supreme with a 350 Rocket . Ran great in the fall . Pulled it out and drove a bit. Stalled at 2 lights.. was really hard to restart. Starter kept turning and turning . Got to destination and when I went to leave battery was dead. Gen light stayed on.. Replaced battery. Also replaced starter . Battery kept going dead .. replaced alternator . Went ahead and changed oil and plugs. And horn relay. Gen light went off. Drove today and did fine .. started to bog out while ideling.. .reved in neutral..and kept going. Next light it died. Tried to restart and it would crank and crank..after sitting a bit ..and mashing gas it started . Drove enough to get home. Any assistance at this point would be super helpful.
Check for vacuum leaks, especially the hose going to your brake booster. I've seen it where it runs fine in neutral, but when you put it in gear, the engine tilts just enough in its mounts to open up a crack in that hose and result in a big leak and a tendency to stall.
Nice looking '68 BTW.
Any assistance at this point would be super helpful....
Yes, we need more info... and not to be an AH but you need to stop throwing parts at it and do some investigative troubleshooting. It's either fuel or electrical related. Hope you kept any original parts you took off?
Points or electronic distributor?
Carb? Q-Jet or? 2 or 4 bbl? Age? Ever been kitted(rebuilt)?
Gas fresh?
What is the running voltage at the battery?
You are gonna need some basic tools:
Vacuum/Fuel gauge.
Volt/Ohm Meter.
Spark tester. Install it on one of the driver's side plugs and run the car. Test drive. When it dies crank it and observe the tester. Flashing while cranking? Yes...sparks there.
Now, look at the carb. Are you getting a good pump shot (Squirt) out of the accelerator circuit? Engine off looking down the primaries actuating the throttle... No/Yes?
Is the fuel filter good? Are all vacuum lines all intact? They can look OK and be cracked.
Carb tight on the intake? (careful it's easily wrapped if ovetightened).
Gas fresh?
Vacuum/Fuel gauge.
Volt/Ohm Meter.
Definitely need more info
how long have you had the car, how did it run before ( last time run?) it looks like its had some work done on it ( looks nice)
what distributor? Does it have points or something like pertronix?
you said the carb is a qjet, any stuff like electric fuel pump?
when you changed the oil did it smell like gas?
how did the plugs look, wet, black, tan, white?
maybe add a pic or two w no air cleaner show the distrbutor and carb
