403 in a G body
403 in a G body
Helping a friend with a 403 going to put it in a 83 cutlass supreme. Will a big block oil pan fit with this combo in the chassis or should we use the small block pan. Also looking for head bolts for 403 need the few ones with the studs on the top side.
There is no benefit with a big block pan as they are the same capacity.
To answer the OP's question, all factory Olds pans interchange and fit the chassis. The BBO pan has one advantage over the SBO pan - it has an internal baffle at the sump. Will you notice any difference from this? Unlikely.
Upper is SBO, lower is BBO.
