350 Rocket
350 Rocket
I'm New to the forum but i figured this would be the best way to get real direction on my 350 rocket. i have a 88 cutlass with 307 in it but i want to replace with 350 rocket. i just bought a 350 rocket bare block and wanted advice about which crank, heads, camshaft etc to get to make it perform. im not familiar with oldsmobile. So im kinda in need of info so i can put project together.
You can use your 307 crank and rods, just needs rebalanced. He should be able to get the block together for 2 grand, heads no way. Get either the CP or Probe pistons for it, depending on the shape of the block. What compression are you aiming for?
Like J stated, that isn't going to get you very far, especially with other upgrades you will need like exhaust and cooling. Find a running 403, pop on some older 350 heads for a compression bump and a little cam.
cutlassKing
November 29th, 2010 03:05 PM
gscott819
July 28th, 2009 07:02 PM
esisson
May 22nd, 2008 07:47 PM
