330 teardown - help me solve what these mystery parts are
Old September 26th, 2012, 11:28 AM
1965F85_scholten's Avatar
I just pulled out my 330 for a teardown and in the process found 3 bearings on my shop floor. I am actually thinking these are valves for my oil and transmission cooler lines. I've attached a pic for reference.
I have not torn the engine apart, just pulled it out and they must have just dropped out when I took the engine apart but the lines are the only thing I can come up.
Any ideas what these may be for?
1965F85_scholten is offline
Old September 26th, 2012, 01:29 PM
Never seen them in any part of an Olds motor before. You sure they came from the motor?
joe_padavano is offline
Old September 26th, 2012, 01:38 PM
What did you use to lift the engine?
oldcutlass is offline
Old September 26th, 2012, 02:33 PM
I used a cherry picker . Bolted a chain diagonally across the block and lifted it out.
Old September 26th, 2012, 02:35 PM
Also, found a couple of the bearings before I even pulled it out. Pretty sure they weren't there prior to unbolting everything.
Old September 26th, 2012, 02:48 PM
I just can't think of anything those would come out of.
Old September 26th, 2012, 03:07 PM
Old School Olds
tru-blue 442's Avatar
Bearings from the castors of the hoist?
Never seen any ball bearings out of any Olds.
tru-blue 442 is online now
Old September 26th, 2012, 03:27 PM
L69
L69's Avatar
This boogles the mind. Never seen them before. Agree with tru-blue posibly from the hoist castors. Check your hoist see if the castors look ok
L69 is offline
Old September 26th, 2012, 04:01 PM
Checked the hoist. The cheap thing doesn't even have bearings in the castors. Like I said, small chance they are not from the motor/tranny somewhere.
Anyone know if cooling lines in a 65 cutlass with jetaway transmission had a check valve?
Old September 26th, 2012, 04:21 PM
FYI: I should clarify. I pulled the tranny out along with the motor so disconnected everything from the tranny forward.
Old September 26th, 2012, 04:26 PM
m371961's Avatar
Are you sure they are not out of your casters? Not caster wheel to axle, but where the caster swivels and turns direction.
m371961 is offline
Old September 26th, 2012, 04:32 PM
jeffsims's Avatar
Could be from the steering box? Have you seen any damage to the box?
jeffsims is offline
Old September 26th, 2012, 04:48 PM
Yes, sure they are not. You are right, the swivel castors have bearings but none are missing and these bearings are about 2x the size of the castor bearings.
Old September 26th, 2012, 04:53 PM
No damage to the steering box. I had already checked that.
....the mystery continues.
Maybe they don't belong to the motor, tranny, or anything else attached to the car. I just better make damn sure it's not when I put the thing back together.
1BOSS83
November 9th, 2014 05:34 AM
Napoleon Solo
October 29th, 2012 12:18 PM
F15david
August 10th, 2012 02:32 PM
garneyflanch
June 28th, 2012 09:31 AM
mrwilde
May 22nd, 2007 01:04 PM
Quick Reply: 330 teardown - help me solve what these mystery parts are
