330 intake swap
330 intake swap
I am swapping intake’s on my 330. The performer intake will not sit flat because the valley tray is in the way. Should i remove this piece or trim it so the intake will fit? I am using a performer intake by the way.
What gasket are you using? If you want a tray, pick up the Felpro 96009 turkey tray gasket and just use it with RTV around both sides of the 4 water ports and a good tall bead of RTV on both end rails instead of the gaskets. I use Aviation sealant around the intake and crossover ports as well.
Just adding this piece of info -> a Performer RPM is preferable over the standard Performer intake. My 67 4-barrel iron intake had bigger intake runners than the Performer. I think the Performer intake was probably an improvement over the smog heads or maybe better than a 2-barrel intake, but if you haven't already installed the intake, would be wise to go with a performer RPM if you can.
