1984 Cutlass Supreme V6 3.8
Hey Guys!
I just got a 1984 Cutlass Supreme V6 3.8. The engine is bad, I was wondering what bigger engine can I fit without doing to much modifications. Appreciate the info in advance.
These cars could have the 3.8 V6, Chevrolet 305 V8 or Olds 307 V8, meaning about any SBC or small block Olds would easily fit. If you choose the Chevrolet or Olds V8, you need to get the motor mount frame perches and ALL of the belt-driven components' brackets from the donor engine. It'll save a lot of aggravation and time searching for the stuff later.
You could possibly look into a 4.1 (252ci) Buick V6 but that might not be easy to find. Also the Chevy 4.3 V6 should bolt up to Chevy frame perches but I'm not 100% on that.
And then there's the LS swap, but I purposely don't know anything about that.
Might as well figure on going through the transmission too if you go the V8 route.
Thanks for the tip guys. Question is this V6 slow?. From what I was researching it seems they have very low HP. Do you guys have any experience this V6. Also where do you guys buy motors online if any sell?
The motor mount frame pads are unique to the Buick motor. You will need to swap to the correct frame pads for whatever other GM motor you plan to use. Only Buick motors bolt to the current mounts.
Your trans is a TH200C. It's marginal behind the V6. Anything with more power probably wants an appropriate trans.
The frame on the G-body cars is not symmetric, so depending on the trans you pick, you may need a different crossmember. The TH200 crossmember also works for the TH350 and most GM manual transmissions. The 200-4R crossmember also works for the TH400.
If you plan to install an Olds motor (and any small block Olds motor is an easy bolt-in with the correct frame mounts), the 260, 307, 330, 350, and 403 are all externally identical.
Any different motor will require matching accessory brackets, starter, and exhaust. Buick and Chevy starters mount on the passenger side, Pontiac and Olds on the driver side. Wiring and battery location change as a result.
If you do plan to install an Olds motor, these are the frame pads you need. Note that they are RH/LH. Anchor 2328 motor mounts are the correct mounts for these pads.
The GM 3.8l is the most dependable engine GM ever built. I'm actually surprised if your's suffered bottom end damage. There were many different versions. You can check your VIN.
https://en.wikipedia.org/wiki/Buick_V6_engine
FWIW, the only engine I might consider more durable is the Ford 4.9l I6.
Wow! I suppose even the old reliables are susceptible to abuse. How long did they have to run it low on oil for that to happen?
The OP might want to tell us why he needs a new engine too. Does this 3.8l have horrible knock when idling?
