1970 oldsmobile cutlass with 1977 350 rocket
Please help 1970 oldsmobile cutlass with 1977 350 rocket
Could some one please tell me in detail how too advance the timing on this motor please it is all orginal motor I have a 600 edelbrock 4b on it with a edelbrock breather I have ordered long tube headers also whyle in neutral it runs fine can rev it up slowly but if you try too lay on the fuel it will try and die out also whyle driving it does the same thing any pics and info would be greatly appreciated
First off it could be the Edelbrock carb, many have issues with them. The timing advance is done by loosening a hold down to right of the base. Advancing, push the vacuum advance towards the firewall. You want 20 degrees at idle with the vacuum advance unhooked with the hose plugged.
Oh jesus......unfortunately, if you super heat it with acetylene and it doesn't come out, it will most definitely need to come off the engine and get drilled out. Man, that sucks. BUT if you do need to pull the head off, may as well pull the other off and replace with a set of earlier heads. Sorry to be the bearer of bad news....
You might be able to drill out the broken bolts from below if you have it up on a hoist. Of course, you'll need a right angle drill and short drill bit. Make sure you are centered and straight with the hole. You might be able to have a good "muffler shop" remove the broken bolts. I think your best bet is to have a GOOD muffler shop drill out the broken bolts and put the headers in.
jkoester122
August 30th, 2011 05:04 PM
